Random Numbers
Results 1 to 13 of 13
Thread: Random Numbers
    Like maybe use a floating pin or some other means for a spare pin to pick up some "static"
    This has crossed my mind also ( didnt tryed yet though ).
    I think that you can get decent random results using a spare pin with ADC grabbing nothing but noise.
    You can then get 1 ou 2 bits from that "noise" which i believe it would be pretty random.
    Dec 2005
    So Cal and loving it
    This is untested, but was thinking of trying it someday....
    The theory.
    Leave an analog pin floating and take a voltage measurement to use as the seed for the random number.
    Not sure how mach variation there will be in each of the measurements. The other thing would be to reduce the sample time for the conversion which may give to less accuracy and give better random results.
    Also, if the pin is connected to a wire or long track, it should act as an antenna and increase the variation in the measurements.
    Maybe some of the experts around here will have any ideas if this could work
    Paul
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Oct 2007
    The Netherlands
    I once did a project that used a DS18B20 temperature sensor. I used this sensor to also make the seed number for the random generator, worked quite well.
  1. Questions on random numbers and multiplexing LEDs
    By AaronM in forum mel PIC BASIC Pro
    Last Post: - 17th June 2009, 05:22
  2. Replies: 4
    Last Post: - 15th April 2009, 02:54
  3. Limite random numbers from 1 to 9
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 13:34
  4. 6 random numbers limiting to 49 ?????
    Last Post: - 16th June 2005, 00:27
  5. random numbers 1-4
    By tekdavid in forum mel PIC BASIC
    Last Post: - 30th March 2005, 12:05
