Newbie question on dataloging.
Results 1 to 8 of 8
    Guess it depends what sort of engine you're trying to do some datalogging on...
    Single cylinder lawnmower engine - could probably get away with a 12F683
    Datalogging on a B-36H, well, 168 cylinders, 336 spark plugs, 4x J47 jet engine, now you need something a bit more substantial...
    Voltage inputs - It's all in your chosen PIC's 'Electrical Specifications' section of the datasheet.
    Dec 2008
    A regular 4 stroke 6 cylinder car engine.
    Im trying to save some time here.
    we both know a lawn mower engine will not have map, maf, tps, o2, coolant temp etc, servo motor position etc
    Quote Originally Posted by wbjunkie View Post
    Other than the obvious economical reasons...Why not? As crazy as emission regulations are getting these day, I can see it happening sooner or later...either that or we all get electric mower and move the emissions concerns to the power plants! I attached a standard 3-wire O2 sensor to a 17HP Koehler exhaust awhile back, just to see what was what. Of course, by the time I leaned it out to stoich, it didn't have any leftover grunt to pull thru tall grass, and practically no acceleration.
    You may be trying to save some time, so why not save us some time while you're at it...
    Are we talking about an engine already installed in a vehicle? A production vehicle, such as a Chevy, or a Honda? Or a sort of homemade 'dune buggy' off-road type machine?
    Fuel injected or carb'd?
    Does it all matter? Well, yes, maybe no. Depends. A post '96 V-6 already installed in a production vehicle would be a relative piece of cake to get that data already formatted for you. Something a bit earlier, yes, that'll need a lot of analog signal conditioning before you can get reliable, repeatable results.
    So....whatcha got?
    Dec 2008
    well obvioully its not a modern car for if it was then a 40$ ODB scan tool would tell me everything I need to know.
    This more of a debug tool to use when your rushed for time. Track side or in the pit lane.
    We typically have a mix of engines from a Chevy 1.6 to a suzuki 1.3 to a various other engines. All pre ODB. Or if they have ODB its not to an open standard. The company wants to sell you their 5000$ proprietary scan tool.
    The idea is to just hook up each lead to each of the sensors. Signal conditioning has pretty much been covered in the Micro chip app note.
    As you know typically all sensors will output a 0-5 volt voltage or a Resistive value. We basically need to know that the sensors are all working.
    So your looking for RPM input at least 4 inputs for 0-5 volts and another 3 for resistance based measurements.
    May have been faster for me to just read the data sheets.
    And you did not tell us how much data you want to log and what you will do with it after you have logged it. Post process on a PC?
    With all of the chips out there this is an open ended question, but one with plenty of ADCs and a fair amount of memory is the 18F6680. Or if you want almost unlimited log storage maybe a 16F877A and a VDIP1 or a SD card?
    Microchip website has a 'parametric search' tool. Select your parameters (i.e. number of A/D inputs, pin count, memory size, and so on) and it'll narrow down the chips based on those inputs.
    Dec 2008
    thanks guys
    found this
    http://www.dataq.com/products/startkit/di194rs.htm
    24$ with software is cool.
  1. Newbie 74hc595 question
    By manjero in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 22:22
  2. newbie with serial com question...
    Last Post: - 16th December 2006, 05:34
  3. Newbie Question - Info Please
    By ehoskins in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 14:50
  4. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 15:52
  5. Newbie question
    By senojlr in forum General
    Last Post: - 11th April 2006, 21:23
