Pic 16Fxx Battery Charger Help
Results 1 to 7 of 7
    Dec 2008
    I thought it was a fuse and shorted it that when the IC blew up.
    The 7805 is actually the ic to the bottom right of the pic.
    The burnt IC is what actually supplies the power to the 7805.
    The IC is taking the 15-18 volts a/c from the transformer converting it to d/c and sending it to the 7805 guess I should supply 12 volts directlly to the 7805 and see if the pic boots up.
    Quote Originally Posted by wbjunkie View Post
    Might just be a diode bridge or full wave diode and not an IC.
    Dec 2008
    considering both pins are connected to the black diodes I doubt this.
    What are the chances of it being a LM317
  1. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 10:44
  2. Pic Battery Charger
    By Squibcakes in forum Off Topic
    Last Post: - 22nd January 2012, 05:56
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 19:15
  4. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 00:12
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 13:16
