Pic 16Fxx Battery Charger Help
Results 1 to 7 of 7
    Dec 2008
    Default Pic 16Fxx Battery Charger Help
    Have a BMW battery charger which I desperately need to repair.
    Have studied the posts discussing how to build such a circuit on this forum. Have also seen the application note on the Pic Micro web site but am still lost.
    Here is a picture of the circuit
    http://rapidshare.com/files/172960057/bmw1.jpg.html
    Anybody willing to take a guess at what the SMD 4 Pin IC which is under the 4 white leds dead center.
    Also to its left is a white box marked T2 these are the only two items which are damaged / burnt and need replacing.
    Oct 2003
    holland
    If you mean the one with 1 pin left and 3 pins at the right side of the component than I can tell you that it is a small power transistor or a fet.
    The middle pin of the left side is connected to the left pin.
    If you can read something on it may be I can tell what it is then.
    Dec 2008
    here is another picture.
    I have circled the items in doubt one is a white box labeled T2
    The other is the IC with 3 legs and a thick top (Dead Center top)
    If I could even have a look at a working unit it would help but the guys on the BMW forum are not much help nor are the guys who made this unit.
    There are 4 points sticking out the epoxy and the PCB is soldered onto these 4 poles. They provide 15 volts a/c. My first problem is that my 7805 which powers the pic is not geting any input voltage. The input is traced back to the burnt component. So it must be taking the a/c voltage in and converting it to d/c before passing it on to the 7805.
    If I short T2 the unit seems to boot up but I see smoke from the burnt IC.
    The circuit looks identical to the ones you guys built here and to the application note on the Pic site. I can take a wild guess what it is. But really need a part number to buy a replacement.
    Oct 2003
    holland
    When I look how this all is connected, then I think the T2 component is a fuse of 2 Amp slow, and the other component is a voltage regulator like 78M05 smd.
    Dec 2008
    I thought it was a fuse and shorted it that when the IC blew up.
    The 7805 is actually the ic to the bottom right of the pic.
    The burnt IC is what actually supplies the power to the 7805.
    The IC is taking the 15-18 volts a/c from the transformer converting it to d/c and sending it to the 7805 guess I should supply 12 volts directlly to the 7805 and see if the pic boots up.
    Quote Originally Posted by wbjunkie View Post
    Might just be a diode bridge or full wave diode and not an IC.
  1. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 11:44
  2. Pic Battery Charger
    By Squibcakes in forum Off Topic
    Last Post: - 22nd January 2012, 06:56
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 20:15
  4. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 01:12
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 14:16
