Caller ID
Results 1 to 2 of 2
Thread: Caller ID
    Jan 2007
    Brazil
    Post Caller ID
    Hello you all....
    I've built this caller ID using a 16F877 and MT8870 (dtmf decoder).
    When I get a phone that is online with the decoder and press the buttons, the LCD shows what numbers are being pressed...ok until that....
    The problem is: when I receive outside callings, it does not work.
    Well, the service of caller ID is working because there is another phone that detects the caller's number.
    Any ideas of how to solve this?
    Thanks in advance!!
    Sylvio,
    Jun 2005
    Up the bush, Western Plains, NSW Au
    The CID info is not in DTMF. It is 1200bps serial ascii data which comes in between the first and second ring. IE "ring-ring (or just ring if not GB or Au or other countries that use double ring ringing)-CID burst-ring-ring etc"
    you probably need a modem chip to read it, or a dedicated CID decoder chip. I believe you can get DTMF decoders with built in CID decoding.
    Hope this helps.
    Peter Moritz.
    New South Wales,
    Australia.
  1. Help needed with Select Case?
    Last Post: - 2nd January 2008, 01:12
  2. Storing numbers for caller ID?
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 28th March 2005, 11:27
