darrel taylor's instant interrupt compiler error
Results 1 to 17 of 17
    Oct 2009
    Austin, Texas
    Default Can I add my errors?
    I know this is an old thread, but I hope you don't mind me adding my error messages to the ones already corrected previously....I am using a PIC16F636. It has (1)8-bit timer, (1)16-bit timer. I have aready commented out errors wsave2 and wsave3.
    Why am I getting these errors?:
    Error TIMER~1.ASM 489 : [224]local drive only for use in macros
    Error TIMER~1.ASM 489 : [225]undefined symbol 'iflagreg'
    Error TIMER~1.ASM 489 : [226]numeric constant or symbol name expected
    Error TIMER~1.ASM 489 : [201]')' expected
    Error TIMER~1.ASM 489 : [235]opcode expected instead of 'error'
    Error TIMER~1.ASM 497 : [225]undefined symbol 'iflagreg'
    Error TIMER~1.ASM 497 : [300]too many errors
    I am trying to do a 20 minute and then a 50 minute event trigger using this process that you have show us. I really hope to get this working properly to salvage my project.
    I don't mind.
    You need to use MPASM for the assembler.
    It won't work with the default PM.exe.
    hth,
    Oct 2009
    Austin, Texas
    MPASM? I am a rookie and not familiar with this.....sorry. Is there more you can tell me or where to go for more? I am using PBP now, is this the problem?
    Thanks for the fast reply....I really appreciate your help.
    I just surfed my software settings and see where the ASSEMBER tab is located....it is in the "Compile and Program Options" pop-up. What should i do from there?
    Okay...I searched for the MPASM location automatically, and I now have compile without errors. Sorry for the learning curve Darrel, and thanks for the info.
    Which version of PBP do you have?
    If you have 2.60, then you can download the latest version of MPLAB (contains MPASM) from here ...
    http://www.microchip.com/stellent/id...&part=SW007002
    If you have an older version, then 8.15 is the last version that you can use.
    You can get 8.15a from melabs...
    http://www.melabs.com/support/mplab_old_versions.htm
    Then after you've installed it ...
    In MCS, go to the View | Compile and Program Options | Assembler Tab
    Click the Find Manually ... button and point it to
    C:\program files\microchip\mpasm suite
    Then check the Use MPASM checkbox.
    hth,<hr>
    Oops, you beat me to it.
  1. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  2. Usart with Darrel Instant Interrupt
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 17th February 2008, 01:09
  3. using darrel taylor's instant interrupts
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 05:07
  4. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 12:20
  5. Instant Interrupt Error
    By cool_justin in forum mel PIC BASIC Pro
    Last Post: - 9th June 2006, 00:40
