darrel taylor's instant interrupt compiler error
Results 1 to 17 of 17
    May 2008
    Italy
    Default I am anable to compile it
    Very likely I am missing somthing because I am unable to compile the DT_Ints-14 with 16F84A & 16F873 while 16F876 will compile with some warnings.
    Here the simple code:
    LED1 VAR PORTB.1
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    INT_Handler INT_INT, _ToggleLED1, PBP, yes
    @ INT_ENABLE INT_INT ; enable external (INT) interrupts
    PAUSE 1
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
    These are the errors with 16F84A with "@PIR1 = EECON1" or w/o it (Flash 1024)
    ERROR: Variable wsave3 position request 416 beyond RAM_END 79.
    ERROR: Variable wsave2 position request 288 beyond RAM_END 79.
    ERROR: Variable wsave1 position request 160 beyond RAM_END 79.
    These are the erros with 16F873 & 16F874 (Flash 4096)
    ERROR: Variable wsave3 position request 416 beyond RAM_END 255.
    ERROR: Variable wsave2 position request 288 beyond RAM_END 255.
    These are the warnings with 16F876 (Flash 8192)
    Warning[205]c:\..................................\led_int.asm 495:Found directive in column 1. (endm)
    Warning[206]c:\..................................\led_int.asm 496:Found call to macro in column 1. (INT_CREATE)
    Warning[206]c:\..................................\led_int.asm 494:Found call to macro in column 1. (INT_Handler)
    I did not check if the above compilation was working or not ( the harware I had prepared was for 16F84A)
    The only explanation I am giving is the ram space, but since others have used with success the 16F84A with the same program, that means that the problem is with my compiler (ver 2.47) or something wrong I am doing.
    Any help will be greatly appreciated.
    Al.
    For the wsave errors. Open the DT_INTS-14.bas file and at the top you'll see a section that says ...
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    For the "Found in column 1" warnings.
    You must maintain the proper indentation of the ASM blocks, as seen in the original examples.
    DT_INTS-14 (Hello World)
    http://www.darreltaylor.com/DT_INTS-14/hello.html
    May 2008
    Italy
    Thank you Darel, for the prompt answer. Problem has been fixed.
    Now program compile (using @PIR1 = EECON1) correctly, and I can proceed experimenting with interrupts.
    Thank you again for your kindness. With the occasion, I whish you:
    Merry Christmas and Happy New Year
    Al.
  1. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  2. Usart with Darrel Instant Interrupt
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 17th February 2008, 00:09
  3. using darrel taylor's instant interrupts
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 04:07
  4. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 11:20
  5. Instant Interrupt Error
    By cool_justin in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 23:40
