Advice-scrutiny for my serial controller
Results 1 to 4 of 4
    Dec 2005
    Salt Lake City, Ut, USA
    Question Advice-scrutiny for my serial controller
    Hello all,
    It's been a long while since my last project...here I go again! I would like some advise-scrutiny-thoughts regarding my latest endeavor. It involves two "boards": a master board (with loop-out to other masters), and daughter boards (4 per master). The master is a 16F871, and the daughters each have a 16F88. I would love some pointers as to proper register setups, uart setups, etc. Most of all, if it'll work at all with how I'm trying to command them! I'll let the code explain the rest.
    Thank you all for helping a long-time newbie!
    ' MASTERBOARD.BAS
    'TO DO: SET ALL REGISTERS AND DEFINES
    Include "modedefs.bas"
    define OSC 20
    ADCON1 = %00000110
    SerInPin    var PORTC.7
    SerOutPin   var PORTC.6
    ADRpin      var PORTB.0
    ProgLED     var PORTB.7
    HrtbtLED    var PORTB.6
    Address     var byte
    OutPin      var byte
    OutLevel    var byte
    BoardAdd    var byte
    UpdPinLvl   var byte
    low Progled
    LOW HRTBTLED
    Start:
        if Adrpin then
            serin SerInPin,t9600,["ADDRESS"],boardadd
                IF (boardadd > 0) and (boardadd < 256) THEN
                    write 0,boardadd
                    high Progled
                    low progled
                    serout seroutpin,t9600,["Board address set to ",boardadd,13]
                    serout seroutpin,t9600,["Error: Address ",boardadd," not valid! Please use 1 to 256.",13]
            goto Start
            read 0,boardadd
            serin SerInPin,t9600,["A"],address            '1 - 256
                IF (ADDRESS > 0) and (ADDRESS <= 256) THEN
                    if address = boardadd then
                        serin SerInPin,t9600,["O"],outpin     '1 - 24
                            if (outpin > 0) and (outpin <= 24) then
                                serin SerInPin,t9600,["L"],outlevel   '0 = OFF, 5 = 5%, 10 = 10%, ...50 = 50%,...100 = 100% (by 5's)
                                    if outlevel <= 100 then
                                        write outpin,outlevel            'Output will match EEPROM location
                                        read outpin,UpdPinLvl
                                        serout seroutpin,t9600,["Updated output ",outpin," to level ",UpdPinLvl * 5,13]
                                        select case outpin
                                            case 1
                                                serout portA.3,n9600,[UpdPinLvl]    'CAT5 JACK 1, PIN 1
                                            case 2
                                                serout portB.1,n9600,[UpdPinLvl]    'CAT5 JACK 1, PIN 2
                                            case 3
                                                serout portA.2,n9600,[UpdPinLvl]    'CAT5 JACK 1, PIN 3
                                            case 4
                                                serout portB.2,n9600,[UpdPinLvl]    'CAT5 JACK 1, PIN 4
                                            case 5
                                                serout portA.1,n9600,[UpdPinLvl]    'CAT5 JACK 1, PIN 5
                                            case 6
                                                serout portB.3,n9600,[UpdPinLvl]    'CAT5 JACK 1, PIN 6
                                            case 7
                                                serout portE.0,n9600,[UpdPinLvl]    'CAT5 JACK 2, PIN 1
                                            case 8
                                                serout portA.5,n9600,[UpdPinLvl]    'CAT5 JACK 2, PIN 2
                                            case 9
                                                serout portE.1,n9600,[UpdPinLvl]    'CAT5 JACK 2, PIN 3
                                            case 10
                                                serout portA.4,n9600,[UpdPinLvl]    'CAT5 JACK 2, PIN 4
                                            case 11
                                                serout portE.2,n9600,[UpdPinLvl]    'CAT5 JACK 2, PIN 5
                                            case 12
                                                serout portA.4,n9600,[UpdPinLvl]    'CAT5 JACK 2, PIN 6
                                            case 13
                                                serout portC.3,n9600,[UpdPinLvl]    'CAT5 JACK 3, PIN 1
                                            case 14
                                                serout portC.2,n9600,[UpdPinLvl]    'CAT5 JACK 3, PIN 2
                                            case 15
                                                serout portD.0,n9600,[UpdPinLvl]    'CAT5 JACK 3, PIN 3
                                            case 16
                                                serout portC.1,n9600,[UpdPinLvl]    'CAT5 JACK 3, PIN 4
                                            case 17
                                                serout portD.1,n9600,[UpdPinLvl]    'CAT5 JACK 3, PIN 5
                                            case 18
                                                serout portC.0,n9600,[UpdPinLvl]    'CAT5 JACK 3, PIN 6
                                            case 19
                                                serout portD.4,n9600,[UpdPinLvl]    'CAT5 JACK 4, PIN 1
                                            case 20
                                                serout portD.5,n9600,[UpdPinLvl]    'CAT5 JACK 4, PIN 2
                                            case 21
                                                serout portC.5,n9600,[UpdPinLvl]    'CAT5 JACK 4, PIN 3
                                            case 22
                                                serout portD.6,n9600,[UpdPinLvl]    'CAT5 JACK 4, PIN 4
                                            case 23
                                                serout portC.4,n9600,[UpdPinLvl]    'CAT5 JACK 4, PIN 5
                                            case 24
                                                serout portD.7,n9600,[UpdPinLvl]    'CAT5 JACK 4, PIN 6
                                        END SELECT
                                        serout seroutpin,t9600,["Error: Level ",outlevel," is not valid! Please use 0 to 100 (By FIVES).",13]
                                serout seroutpin,t9600,["Error: Output ",outpin," is not valid! Please use 1 to 24.",13]
                    serout seroutpin,t9600,["Error: Address ",address," is not valid! Please use 1 to 256.",13]
        TOGGLE HRTBTLED             'Flashing pretty damn fast!
    goto Start
    'DAUGHTERBOARD.BAS
    DEFINE WRITE_INT 1
    INTCON = %10010000
    DimVal var byte
    DimTblVal var byte
    DimStore var byte
    DimPause var byte
    SerPin var portB.2
    ZeroCross var portB.0
    TriacTrig var portB.1
    ON INTERRUPT GOTO ACDetect
    Start:
    serin serpin,t9600,dimval   'grab the Dim Value (0,5,10,15,...95,100)
    write 0,dimval              'store the dim value in mem pos 0
    read 0,DimStore             'read mem 0, put it in DimStore
    dimstore = dimstore / 5     'convert 0-100 to 0-20 for lookup table (0=0, 5=1, 10=2, ... , 95=19, 100=20)
    if DimStore > 20 then goto start       'testing for 0-20, exit if greater than 20
        LOOKUP DimStore,["F",202,195,188,181,174,166,157,147,135,104,74,62,52,43,35,28,21,14,7,"N"],DimPause
    goto start
    ACDetect:
        low triactrig
        select case dimpause
            case "F"            'F = OFF
                low triactrig
            case "N"            'N = ON
                high triactrig
            case else
                pauseus dimpause * 5    'multiply 8 bit value by 5 for true delay
                high triactrig          'fire triac after delay
         end select
         RESUME
    Are you wanting to change from SERIN/OUT to using the hardware ports?
    Dec 2005
    Thanks for your inquiry.
    I suppose, moreover, I'm in need of assistance with the intricacies of the USART registers, interrupts, etc. I've been reading a few posts here regarding "lost" bytes due to buffer overflows. I'd sure love a quick interrupt routine to avoid that problem (maybe parsing the bytes? I dunno?). I'm also interested in a pro reviewing the code and giving a yeah or nay to it, as far as basic functionality. If nay, I'll go back to the drawing board with suggestions-fixes in tow. I certainly don't expect any of you guys to do the project for me, just pro advice for a newbie that's a bit confused. Maybe one of you guys could put the boards through their paces on a simulator? Am I on the right track as far as the commands coming from the pc serial port?
    "AxOyLz"
    ...where x = address 1-256 (8 bit)
    After "A", grab next byte
    ...where y = output 1-24 (8 bit)
    After "O", grab next byte
    ...where z = level 1-100 (8 bit)
    After "L", grab next byte
    I hope all this gibberish is not confusing to you! Just trying to fly-out my questions rattling in my noodle right now.
    Anyhow, after posting the "masterboard" code, I revamped it a bit...hopefully for the better?
    Thanks again for your time and advice.
    ' MASTERBOARD.BAS
    '       MAYBE AN INTERRUPT ROUTINE FOR SERIAL IN?
    define OSC 20
    'DEFINE HSER_RCSTA 18h   ' Set receive register to receiver enabled
    'DEFINE HSER_TXSTA 98h   ' Set transmit register to transmitter enabled
    TXSTA = %00100100
    RCSTA = %10010000
    ADCON1 = %00000110
    TRISA = %00000000
    TRISB = %10000000
    TRISC = %00000000
    TRISD = %00000000
    INTCON = %01000000
    PIE1.5 = 1          'USART RX INTERRUPT ENABLE
    SerRxOK     var PORTB.4
    ADRpin      var PORTB.0
    ProgLED     var PORTB.7
    Address     var byte
    OutPin      var byte
    OutLevel    var byte
    BoardAdd    var byte
    UpdPinLvl   var byte
    low Progled
    LOW HRTBTLED
    Start:
        if Adrpin then
            serin SerInPin,t9600,["A"],boardadd
                    write 0,boardadd
                    high Progled
                    low progled
                    serout seroutpin,t9600,["Board address set to ",boardadd,13,10]
                    serout seroutpin,t9600,["Error: Address ",boardadd," not valid! Please use 1 to 256.",13,10]
            goto Start
            read 0,boardadd
            IF (BOARDADD = 0) OR (BOARDADD > 256) THEN
                serout seroutpin,t9600,["Board is not addressed. Please set address between 1 and 256.",13,10]
                goto start
                IF ADDRESS <> boardadd THEN
                    goto start
                if (outpin = 0) or (outpin > 24) then
                    serout seroutpin,t9600,["Error: Output ",outpin," is not valid! Please use 1 to 24.",13,10]
                    goto start
                if outlevel > 100 then
                    serout seroutpin,t9600,["Error: Level ",outlevel," is not valid! Please use 0 to 100 (By FIVES).",13,10]
                    goto start
            serout seroutpin,t9600,["Updated output ",outpin," to level ",UpdPinLvl * 5,13,10]
            select case outpin
                case 1
                case 2
                case 3
                case 4
                case 5
                case 6
                case 7
                case 8
                case 9
                case 10
                case 11
                case 12
                case 13
                case 14
                case 15
                case 16
                case 17
                case 18
                case 19
                case 20
                case 21
                case 22
                case 23
                case 24
            END SELECT
    goto Start
    Usart is used with HSERIN /HSEROUT, and have a 2 byte buffer. Check out post 16 in the thread below for code which contains a ring buffer up to 64 bytes if I remember correctly.
    http://www.picbasic.co.uk/forum/show...highlight=cren
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  5. LCD serial controller
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2006, 02:56
