PICKit 2 USART
Results 1 to 4 of 4
Thread: PICKit 2 USART
    Nov 2006
    Default PICKit 2 USART
    HI All
    I have look on the website (swordfish) where it use PICKIT 2 to Tx/Rx from PC directly using UART Tool.
    http://www.digital-diy.net/18F%20Exa...CKit2UART.aspx
    I had tried to do it as the website above with the following code. But FAILED!!
    On the UART Tool:-
    Echo is ON. When I type Hello, the screen only shown Hello Once and does not shown Hello Twice (send and echo). WHY??
    ' Set baud rate
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    datain VAR BYTE
         HSerin [datain]
         HSerout [datain]
    GoTo main
    Peter
    You haven't enabled the serial port according to the PBP manual. All you've done is set the baud rate. That's it. HSERIN/HSEROUT are talking to a register that 'doesn't care' until you set the right DEFINEs.
    Have a look, add the code, see what happens.
    Nov 2006
    Hi
    I had added in the Define as below. I'm using PIC16F877A and 4 MHz.
    I enter "a" and click send. There are nothing echo back. "a" only show once when the echo button is checked.
    Any idea???
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_SPBRG 6
    datain VAR BYTE
         HSerin [datain]
         HSerout [datain]
    GoTo main
    Any suggestion ???
    Peter
    Did you try swapping the Rx/Tx pins on one end?
    And while you're at it, try 2400 baud, instead of 9600. Yes, 9600 should work...but 2400 should be a bit more reliable if there are other problems.
  1. Unpacking a PICkit 2 Programmer/Debugger
    By duncan303 in forum General
    Last Post: - 14th May 2009, 21:24
  2. PICkit 2 and RBC interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 4th April 2009, 02:33
  3. PicKit 2 Questions
    By dmairspotter in forum General
    Last Post: - 11th November 2007, 21:10
  5. Programming from MicroStudio to a PICKit 2
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 30th November 2006, 03:56
