Serout/Serout2 on pin RC6
Results 1 to 15 of 15
    Ioannis, Obviously none of you are reading the data sheets for the processors you are trying to program... Set RCSTA.7 to 0 and the port is all yours...
    What!!! Read the data sheet!!! That is just asking tooo much
    Anywho, that is why I suggested
    TXSTA = %00000000
    being we are dealing with the transmit part/pin..
    bit 5 is all that, I thought, needed set to zero.
    Ioannis,
    When I get home this weekend I am going to play with this.
    Thanks Dave. It is not in TXSTA but in RCSTA, bit 7 where the UART is enabled/disaled. But as I stated before, once it is enebled and there are even 1 Hserout command somewhere in the program, I cannot gain control of the port pin. May be I got a defective chip, maybe there is a ghost around. I cannot explain it.
    Before posting usually the manual/data sheet is really dusted good. In vein...
    I will try tomorrow with different system (MCU/PC/Programs).
    I am a little embarrased. I feel like Goofy. Anyway. The problem was the Decimal/Hexadeciml numbers I got confussed.
    Mister-e has involved to this! His utility shows the numbers in Decimal, while the copy variables has a mix of decimal/hex numbers.
    All is working OK now. Sorry for the lost time.
    P.S. I Attache the test code for On the fly Baud Rate changing.
    Me too.
    To switch from hardware to software
    '# 16F877A
    DEFINE OSC 20
    X   VAR BYTE
    START:X = X + 1
    HIGH PORTD.2 :PAUSE 250:LOW PORTD.2:PAUSE 250' HEARTBEAT
    RCSTA=$90:TXSTA=$24:SPBRG=129:HSEROUT ["HSER ",DEC X,13,10]
    PAUSE 250:RCSTA=$0:SEROUT2 PORTC.6,84,["SER ",DEC X,13,10]
    GOTO START
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  3. Serout/Serout2 and PIC18F97J60 (100 pin)
    By mikebar in forum Serial
    Last Post: - 20th May 2008, 05:16
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
