Serout/Serout2 on pin RC6
Results 1 to 15 of 15
    Default Serout/Serout2 on pin RC6
    It is been 2 days now struggling with this simple thing:
    Use the hardware USART output with Serout/Serout2 command.
    It doesn't do anything! Can anyone please tell me why? On the same pin Hserout works OK.
    MCU:16F877, MPASM, PBP2.40
    P.S. Of course if the command (serout/serout2) is changed on another pin it works OK as expected.
    I am sure you do not have the TXSTA register set for enable, but it is the only thing I can think of.
    I have used RC6 with SEROUT/2 in the past with this chip and did not have any trouble.
    Thank pa for the reply. Well, I forgot to mention that I am using the PICDEM2 board with the ICD2 without the debugger. Is it possible that the ICD2 keeps the port for itself? If yes why does the Hserout works OK?
    The last rules out the setup case.
    How will the TXSTA come in the middle relative to Serout?
    Also I tried to pull low the portc.6, but is not possible. So I think it has to do with the ICD2 thing.
    I was thinking that the TXSTA if enabled would be tying up the pin.
    Not sure about the ICD2.
    I got confussed thinking that ICD2 uses the RC6/RC7 pins. Nop. The poblem I think is that I used the DEFINES on top of the program and the UART is holding the pins for itself. UART has higher priority than TRIS i suppose. I'll try and come back.
    Yes. This is the problem. When there is a Hserout command inside the program (no matter where, even at the end), the TX pin is engaged by the UART and cannot be controlled.
    Now I have to find out how to release it from the UART control.
    TXSTA=2 and RCSTA=0 did not help.
    What I really want to do is to emulate a 1200 baud trasnmission of one zero (0), like this:
    LOW PORTC.6
    PAUSEUS 7500
    HIGH PORTC.6
    That way there is no need to deal with BAUD rate change. If it only worked...
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  3. Serout/Serout2 and PIC18F97J60 (100 pin)
    By mikebar in forum Serial
    Last Post: - 20th May 2008, 04:16
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
