Hserin
Results 1 to 12 of 12
Thread: Hserin
    Default Hserin
    Hello,
    I'm pulling my hair out, so I got on this forum hoping that someone could help me with my sanity.
    I am trying to create a Christmas show with some boards that I built earlier this year. I am transmitting using xbees to onboard pics from a piece of software called vixen. Vixen transmits a string like the following:
    In hex:
    7E 80 00 FF 00 00 00 00 00 00 7E 81 00 00 FF 00 00 00 00 00 7E 82 ...
    The 7E is some sort of like identifier and the 80, 81, and 82 are the "box" that the data is intended for. The following 8 hex values are then the brightnesses of each of the 8 channels on board.
    I setup HSERIN like this:
    HSERIN [wait($7E),wait($80),STR INP\8]
    It seems to work fine, when the identifier is the last one in the string, so for the example above, my identifier would have to be $82 in order for the device to work correctly. In other words, the rest of my boxes with identifier 80 or 81 would not receive everything correctly.
    Any help would be greatly appreciated!
    Receive 9 bytes to the array, and test for the "Box" code after receiving the data.
    Maybe something like this...
    HSERIN [wait($7E),STR INP\9]
    SELECT CASE INP(0)
        CASE $80
             ; The data for Box $80 is in INP(1 thru 8)
        CASE $81
             ; The data is for Box $81
        CASE $82
             ; The data is for Box $82
    END SELECT
    Thanks for the response.
    I tried loading the 9 characters after the $7E, and then running it through the case statement and I get the same problems.
    I tried sending back out serially what I am was loading into inp, and I realized that I think that actually it is receiving correctly, but in fact that it has something to do with the dimming. I don't know if anybody has the time to look at all of this, but I'll attach my code below and see if anybody catches anything that I'm not.
    DEFINE HSER_RCSTA 90h ' Enable serial receive
    DEFINE HSER_TXSTA 24h ' Enable serial transmit
    SPBRG = 10
    DEFINE HSER_CLROERR 1 'Clear Overflow Automatically
    PIE1.5 = 1 ' Enable interrupt on USART
    ADCON1 = %01111111
    INTCON = %11000000
    INTCON3 = %10010000
    ON INTERRUPT GoTo Interupt ' Declare interrupt handler routine
    INP VAR BYTE(9)
    TMP VAR BYTE
    LowTimer VAR BYTE
    HighTimer VAR BYTE
    HSEROUT ["Now Operating at 115.2KBps",10]
    TRISA.0 = 0 'Channel 1 'Red
    TRISA.1 = 0 'Channel 2
    TRISA.2 = 0 'Channel 3
    TRISA.3 = 0 'Channel 4
    TRISB.3 = 0 'Channel 5 'Green
    TRISB.2 = 0 'Channel 6
    TRISB.7 = 0 'Channel 7
    TRISB.6 = 0 'Channel 8
    TRISB.0 = 0 'New Channel 8
    TRISB.2 = 1 '120VAC Line In
    PORTA.0 = 0
    PORTA.1 = 0
    Loop:
    'String Reading and Brightness Adjustment
    LowTimer = TMR0L
    HighTimer = TMR0H
    IF HighTimer = 0 THEN
    IF INP(0) > LowTimer THEN
    PORTA.0 = 1 'Channel 1
    GOSUB TRIAC_PAUSE
    PORTA.0 = 0
    IF INP(1) > LowTimer THEN
    PORTA.1 = 1 'Channel 2
    GOSUB TRIAC_PAUSE
    PORTA.1 = 0
    IF INP(2) > LowTimer THEN
    PORTA.2 = 1 'Channel 3
    GOSUB TRIAC_PAUSE
    PORTA.2 = 0
    IF INP(3) > LowTimer THEN
    PORTA.3 = 1 'Channel 4
    GOSUB TRIAC_PAUSE
    PORTA.3 = 0
    LowTimer = TMR0L
    HighTimer = TMR0H
    IF INP(4) > LowTimer THEN
    PORTB.3 = 1 'Channel 5
    GOSUB TRIAC_PAUSE
    PORTB.3 = 0
    IF INP(5) > LowTimer THEN
    PORTB.6 = 1 'Channel 6
    GOSUB TRIAC_PAUSE
    PORTB.6 = 0
    IF INP(6) > LowTimer THEN
    PORTB.7 = 1 'Channel 7
    GOSUB TRIAC_PAUSE
    PORTB.7 = 0
    IF INP(7) > LowTimer THEN
    PORTB.0 = 1 'Channel 8
    GOSUB TRIAC_PAUSE
    PORTB.0 = 0
    Goto LOOp
    DISABLE
    Interupt:
    IF INTCON3.1 = 1 THEN
    TMR0H = 0
    TMR0L = 0
    T0CON = %10000110
    INTCON3 = %10010000
    INTCON = %11000000
    Proceed:
    Resume
    Enable
    triac_pause:
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    The USART settings indicate that you want to receive at 115200 baud, with the CPU running at 20Mhz.
    But since there isn't an OSC defined, PBP defaults to 4Mhz, which would give you the wrong baudrate.
    If you are actually running at 4Mhz, then the closest you can get to 115200, is 125000. That would be a SPBRG of 1.
    Feb 2005
    GREECE
    Question Send hex to PIC-->DS160
    Hello to everybody,
    I have ALSO a problem with HSERIN(?).
    My setup is CPU 16F627A internal OSC 4Mhz.I want to send via a termial(hyper or similar) a byte to pic.
    The PIC reads the byte and it sends to the DS1620 Digital Thermometer and Thermostat.That is not working......
    FOR EXAMPLE if i send via the termial the hex A1 (this is the InChar) I should have take an answer to the terminal with the stored value of high temperature limit.The DS1620 is working with the PIC.
    BUT I CAN NOT FIND THE MISTAKE
    HERE IS MY FULL CODE
    include "modedefs.bas"
    @ DEVICE pic16F627A, INTRC_OSC_NOCLKOUT ' system clock options
    @ DEVICE pic16F627A, WDT_ON ' watchdog timer
    @ DEVICE pic16F627A, PWRT_ON ' power-on timer
    @ DEVICE pic16F627A, MCLR_OFF ' master clear options (internal)
    @ DEVICE pic16F627A, BOD_OFF ' brown-out detect
    @ DEVICE pic16F627A, LVP_OFF ' low-voltage programming
    @ DEVICE pic16F627A, CPD_OFF ' data memory code Protect
    @ DEVICE pic16F627A, PROTECT_OFF ' program code protection
    CMCON = 7 'Turn off comparators
    VRCON = 0
    INTCON = 0 ' Disable interrupts
    ' DEFINE VARIABLES FOR SERIAL TO PC 2400 8-N-1
    ;DEFINE NO_CLRWDT 1
    DEFINE HSER_CLROERR 1 'Automatically clear over-run errors
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    ;DEFINE HSER_CLROERR 1
    ;DEFINE HSER_RCSTA 90H
    ;DEFINE HSER_TXSTA 20H
    ;DEFINE HSER_BAUD 2400
    ;DEFINE HSER_SPBRG 25
    ' DS1620 control pins
    RST var PORTA.4 ' Reset pin
    DQ var PORTA.2 ' Data pin
    CLK var PORTA.3 ' Clock pin
    INPUT PORTA.3
    INPUT PORTA.4
    ' Allocate variables
    temp var word ' Storage for temperature
    InChar VAR byte
    RCIF VAR PIR1.5
    Low RST ' Reset the device
    START:
    While RCIF = 1
    hserin 100,start,[InChar]
    mainloop:
    RST = 1 ' Enable device
    Shiftout DQ, CLK, LSBFIRST, [$ee];Shiftout DQ, CLK, LSBFIRST, [$ee] ' Start conversion
    RST = 0
    Pause 1000 ' Wait 1 second for conversion to complete
    RST = 1
    Shiftout DQ, CLK, MSBFIRST, [InChar] ' Send read command
    HSERout [InChar]
    Shiftin DQ, CLK, LSBPRE, [temp\9] ' Read 9 bit temperature
    RST = 0
    ' Display the decimal temperature
    hserout [" Temp = ",dec (temp >> 1), ".", dec (temp.0 * 5)," oC",13]
    Wend
    Goto START ' Do it forever
    PLEASE I need your advice
    Nikos
    Quote Originally Posted by ngeronikolos View Post
    Use a 4Mhz crystal or resonator instead of the internal 4Mhz.
    HERSIN/HSEROUT are clock sensitive. The DS1620...not so much...
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
