What have I done now?
Results 1 to 20 of 20
    Sep 2007
    Default Still slogging along
    I'm still fighting with this issue and here's where I'm at.
    I uninstalled everything PBP, MPASM, Micro Code Studio Plus and several other IDE's I had loaded a long time ago before getting this thing to work (with much help from everyone here on the forum). And life was good up until a week or so ago!
    I then reinstalled everything today and finally got the settings worked out on the programmer. So I'm sort of back to square one and looking for ideas. I can load hex files that I created literally 3 weeks ago fine. However, when I try to recompile the pbp file, nothing!
    Now when I say nothing, I mean nothing from the board with the chip. The system says that it assembles and compiles fine with no errors. Then it erases the chip, programs and verify's the load and says it programmed successfully, but does nothing.
    So, to summarize. Hex file created weeks ago from a pbp file loads and works fine on chip. Exact same pbp file now, assembles, compiles and loads with no errors, but is like it's not on the chip at all. Hmmm???
    The one thing I was looking at on the MELabs site: http://www.melabs.com/support/mpasm.htm
    was under the xp section trying to figure out what all should be in this path block? What different things should this be point to? Just to Mpasm location, or should it be pointing to other stuff too? Mine was pointing at a whole lot of nothing, so I did at least point it at the folder where Mpasm.exe is located, but that's it right now. And no change to what I posted above.
    I'm grabbing at straws here, has anyone else experienced anything like this?
    Upload a working hex and a non working hex compiled/assembled from the same code so we can take a look at it. we can ckeck the fuse settings from there.
    Sep 2007
    Default Hex file samples
    Here is a working and non working hex file samples from the same code. Rename file extension to .hex
    There is a noticable difference in size of the files. Also, I noticed that on the drop down on the IDC Compile button I've got a couple choices listed:
    Picbasic Pro 2.50
    Picbasic Pro 2.50B
    Picbasic Pro 2.50L
    Originally I had two listed, 2.50 and 2.50L and the 2.50L was checked. So I tried checking the 2.50 just to see what would happen and then the 2.50B appeared. I don't know what the differences in these are but thought I'd throw it out there.
    For what it is worth, The config bits are the same between the two. I have not had time to look any farther yet.
    The notworking file has 17176 bytes, the working file has 5590 bytes.
    Are you sure about compiling the same program? Doesn't look like it to me...
    If the 17176 file was compiled with PBPL, that might make sense since PBPL uses all 32 bit math whereas PBP doesn't.
    Question
    Hi, Hylan
    any chance you post here your source code ???
    just us to try to reproduce the probem ...
    Bombay, India
    I am a bit confused between your first post and the subsequent one. You indicate that the setup is 2 years old and a 2 week old compile works. IIRC, PBP2.50 is of recent vintage. Is it possible you compiled the working file with another version of PBP prior to 2.50? Is that version still available with you so you can backtrack and rule out the compiler change causing this issue? I would like to look at the listing to see if there's something broken here. If you feel insecure posting your code on the forum, you can PM it to me. Cant promise much, but I am willing to help
    PS: after loading both files, I can say that you haven't embedded the configuration into your source code. So, you are possibly setting the oscillator wrong. HS instead of XT or otherwise
    Sep 2007
    Okay, so I looked and it's been less than 2 years. Maybe 2 dog years! I have been using the same version 2.50 the whole time and the same pic 18f6520.
    I did look and the use PBPL box was checked in response to Skimask's post. I assembled and compiled with it checked and unchecked and got the same result (nothing).
    Attached is the source code.
    Is there anything with the path setting under the environmental variables that needs to be set? What all should be in there?
    The only thing I have in there now is a pointer to the MPASM, nothing else.
    Thank you,
    Hylan
