Returning from Int on PortB change
Results 1 to 6 of 6
    Dec 2008
    Unhappy Returning from Int on PortB change
    Hello.
    My PBP ISR works great in PBP...but unfortunately, I have to conver it to asm. The code interrupts on a change on Portb. There are no other interrupts enabled. After the ISR, the code has to go to a new location and NOT RESUME to where it was.
    By using the compiler manual or DT_INTS code (thanks DT), I think I might be able to piece together some of the asm code, but I don't know how to "retfie" to a different location. At the end of the ISR, the code needs to go to the "top" (RESUME top_label). How do I do that in ASM? Any suggestions are greatly appreciated!
    disable
    inthand:
    tempb4=portb
    intcon.0=0 ;reset RBIF
    ;do some things
    ;like wait for portc=0
    tempb4=portb
    resume top_label ; go to new location - do not "return" to old place in code
    enable
    Sheryl
    Hi sheryl,
    It depends on if you're using a 16F or an 18F.
    For 16F's, the stack is circular, so you can just jump to the beginning of the program after resetting GIE. Any previous gosubs or interrupts will be forgotten, or more like Ignored.
    PBP defines the "beginning" of the program as INIT, which makes it easy to do this, instead of retfie...
      bsf  INTCON, GIE  ; re-enable interrupts
      clrf  PCLATH      ; codepage 0
      goto INIT         ; start from the top
    For 18F's, the stack is NOT circular, so you have to POP everthing off the stack before jumping to INIT. Otherwise, the stack will eventually overflow.
    Or you could just reset everything.
    @  reset
    (not the prefered method ... depending again?).
    If you're using an 18F? I'll come up with some code.
    <br>
    Sep 2005
    Campbell, CA
    Darrel,
    I'm using an 18F, and I have come across several instances where such code would be useful. Please...
    Charles Linquist
    Check out this app note: http://ww1.microchip.com/downloads/e...tes/00818a.pdf
    You can do some really cool stuff on the 18F.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2008
    Thank you.
    I am using the 18f4620....so...here's the followup ..how do I pop everything off the stack? since most of the code is in PBP, how do i know how deep the stack is?
    Sincerely,
    Sheryl
    Charles,
    I'm pretty sure you're using DT_INTS with the 18F, so here's a macro that should do the same thing that RESUME LABEL does with ON Interrupt and 16F's.
    I DO NOT recommend actually using it. It's just BAD programming practice. And it will cause more problems than it will alleviate. However, being the capable programmer that you are, you may be able to make some use of it.
    It can be used in place of INT_RETURN.
    With the format ... @ INT_RESUME _Label, IntsEnabled
    @  INT_RESUME  _Main, 1
    The line above would "resume" at the Main: label, with interrupts enabled.
    Changing IntsEnabled to 0, will leave the interrupts DISABLED. In case they need to be setup again from the new "Starting point".
    All previous GOSUB's and Interrupts will be discarded, and the command that was interrupted will NOT be completed. Stopping a PBP command in the middle can cause unexpected results. In particular, the I2C and LCD commands, may be left in the incorrect state. Clearing the Flags register, will correct those two, but other problems can arise.
    The label that is resumed to, MUST be a GOTO Loop, just like the Main loop. It CAN NOT be a subroutine with a RETURN at the end.
    And since it is exiting the interrupt handler without the assistance of DT_INTS, you have to make sure the IF (interrupt flag) bits are cleared before resuming.
    18F's ONLY
    #define Reg(PBPreg, PBPbit) PBPreg  ; Returns the register for a PBP BIT var
    INT_RESUME  macro Label, IntsEnabled
      local PopLoop
    PopLoop                          ; Remove everything from the stack
      pop
      movf   STKPTR, W
      bnz    PopLoop
      ifdef ReEnterHPused            ; let Instant Interrupts know we are
        if (ReEnterHPused == 1)      ;   done with the System variables
          banksel  Reg(_VarsSaved_H) ;   that were saved during the
          bcf      _VarsSaved_H      ;   High Priority interrupt.
      ifdef ReEnterLPused            ; And, we're done with the variables
        if (ReEnterLPused == 1)      ;  saved on a Low Priority INT.
          banksel  Reg(_VarsSaved_L)
          bcf   _VarsSaved_L
      ifdef USE_LOWPRIORITY          ; If Low Priority INTs are being used,
        if (USE_LOWPRIORITY == 1)
          if (IntsEnabled == 1)      ;  and the user specified IntsEnabled
            bsf  INTCON, GIEL        ;    then enable Low Priority Interrupts
          else                       ; if not,
            bcf  INTCON, GIEL        ;   disable LP INTs
      if (IntsEnabled == 1)          ; If the user specified IntsEnabled,
        bsf    INTCON, GIEH          ;   enable High Priority Interrupts
      else                           ; if not,
        bcf    INTCON, GIEH          ;   disable HP INTs
      clrf   BSR                     ; reset to Bank0
      goto   Label                   ; resume from the users Label
    HTH,
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
