PICDIM Lamp Dimmer for the PIC12C508 - PICREF-4
Results 1 to 9 of 9
Threaded View
  1. #4
    O.k
    all you need to know @50Hz
    Period : 20 ms
    1/2 period :10 ms
    i'll prefer to detect begining of each cycle using the appended circuit...
    You must detect begining of cycle, then activate output to TRIAC for a maximum delay of 10ms including when your PIC is detecting the begining of the cycle. Let's say your PIC is detecting the cycle after 1ms of the begining, you must wait a maximum of 9 ms. Can be intelligent to use a PIC who have internal voltage comparator here.
    try the following code as a begining.
    'Using PIC16F628
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _LVP_OFF
    TRISB=%00000001
    BeginingCycle    var PORTB.0
    OutputToTriac    var PORTB.1
    delay            var byte
    Hold             var word
    while BeginingCycle
    wend
    start:
    For delay=0 to 8
         for Hold=1 to 100
              while BeginingCycle=0
              wend
              OutputToTriac=1
              Pause delay
              OutPutToTriac=0
              While BeginingCycle
              Wend
         Next
    next
    goto start
  1. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 09:44
  2. Lamp Dimmer on ME Website
    By jw666 in forum mel PIC BASIC Pro
    Last Post: - 1st August 2007, 18:14
  3. Microcontroller with 2 way paging application problem
