HSEROUT help with HT9200 DTMF encoder
Results 1 to 2 of 2
    Oct 2008
    Default HSEROUT help with HT9200 DTMF encoder
    I am wondering if I could use the HSEROUT command - HSEROUT 8,3,2,6,5,4,3
    for example as a phone number and input this into a HT9200 DTMF encoder as serial into it. How could I basically slow it down to be able to hear the tones? Can you somehow select 4 bit code for 8, serially send that and somehow pause for a 20 ms and then send the 3 ect... Probably not. I can clock the HT9200 to produce the tone using parallel inputs but I wanted to try something serial. Probably way over my head.
    Thanks, Don
    May 2008
    Italy
    Don, with Pic Basic Pro (see page 61 of user manual) you can produce DTMF directly out a pic pin.
    You can serially send your number to the pic which in turn will send out the corresponding DTMF code. In this way, you don't need to use a HT9200.
    Al.
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  3. Replies: 2
    Last Post: - 31st July 2006, 17:06
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
