Air pressure measuring
Results 1 to 11 of 11
    Nov 2007
    Do you mean air pressure as in barometric or as in a compressor?
    As in barometric application .
    This should do the trick
    http://www.omega.com/pptst/HX85.html
    I have not used this particular model, that is why I asked if it was barometric.
    Any how. The way I use other parts from this company is to set up a voltage divider to scale to 0 - 10 VDC down to 0 - 5 VDC. Then use a chip with an ADC port. At least 3 pins will be needed.
    Nov 2007
    Be sure , I do not use it , too . It is more expensive . I have , for a few $ , a Smartec pressure sensor type "SPD030G 0 – 2.0 Bar" .
    Sep 2005
    Campbell, CA
    I use a Silicon Microstructures sensor to measure very small amounts of pressure ( tenths of inches of water) . One of their products may be suitable for your use.
    http://www.si-micro.com/
    Charles Linquist
    Nov 2007
    Quote Originally Posted by Charles Linquis View Post
    Yes ! In special with I2C bus . How much is it ? But is a big problem-in Romania I cannot find it . Have you a application diagram for analog out ?
    Quote Originally Posted by Eugeniu View Post
    Hello Eugeniu,
    Got any automobile junk yards in Romania? Many cars built since the 1980s used a Baro sensor, some used a MAP sensor and others used a combo MAP/Baro sensor. A little research and some bone-yard shopping could result in what you want on the cheap, and then after you have proven your design, if you want a new sensor, you can get it at an auto parts distributor.
  1. SMT Gas Pressure switch, suggestion anyone?
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 31st March 2009, 16:02
  2. Mass Air Flow Sensor Data
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 1st January 2009, 09:35
  3. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 15:52
  4. measuring air speed
    Last Post: - 13th June 2006, 13:40
  5. Time Measuring
    By peterson in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 17:22
