pls help me convert C to PICBASIC
Results 1 to 6 of 6
    Dec 2008
    Default pls help me convert C to PICBASIC
    please help me convert this C code to PICBASIC, it is using SPI protocol..
    #define MaxSayisi 2
    void max6952_putchar(char reg,char data)
    unsigned char dongu=1;
       PORTC.F0 = 0;
       for(dongu=1;dongu<=MaxSayisi;dongu++){
       SPI_WRITE(reg);
       SPI_WRITE(data);
       PORTC.F0 = 1;
       PORTC.F0 = 0;
    void MAX_6952_init(){
       max6952_putchar(0x04,0x01);  //Configuration
       max6952_putchar(0x01,0x0FF);
       max6952_putchar(0x02,0x0FF);
       max6952_putchar(0x03,0x01);
    void main(){
       char a[ ]="   ali raza  ";
       int i;
       TRISC=0B00011000;
       Spi_Init();
       MAX_6952_init();
       while(1)
       for(i=0;i<=10;i++){
       max6952_putchar(0x20,a[i]);
       max6952_putchar(0x21,a[i+1]);
       max6952_putchar(0x22,a[i+2]);
       max6952_putchar(0x23,a[i+3]);
       delay_ms(500);
    this i've done so far...
    Device 16F877A
    XTAL = 20
    ALL_DIGITAL = TRUE
    Symbol CS = PORTC.4				' SPI eeprom CS line
    Symbol SCK = PORTC.3			' Clock pin
    Symbol SI = PORTC.5				' Data in pin
    Symbol SO = PORTC.5
    Dim reg as BYTE
    Dim datas[10] as BYTE
    Dim dongu as BYTE
    MAX6952_Init:
        PORTC.0=0
    	FOR dongu = 1 to 2
    	Shout SI, SCK, MSBFIRST, [0x04]
    	Shout SI, SCK, MSBFIRST, [0x01]
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	PORTC.0=0
    	FOR dongu = 1 to 2
    	Shout SI, SCK, MSBFIRST, [0xFF]
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	PORTC.0=0
    	FOR dongu = 1 to 2
    	Shout SI, SCK, MSBFIRST, [0x02]
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	PORTC.0=0
    	FOR dongu = 1 to 2
    	Shout SI, SCK, MSBFIRST, [0x03]
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    max6952_putchar:
        PORTC.0=0
    	FOR dongu = 1 to 2
    	Shout SI, SCK, MSBFIRST, [reg]
    	Shout SI, SCK, MSBFIRST, [datas[0]]
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	TRISC=%010001100
    	Goto MAX6952_Init
    	reg=0x20
    	datas[0]="A"
    	Goto max6952_putchar
         Delayms 500
    Goto main
    I notice that PORTC.0 is not having output in Proteus when i use my PICBASIC code...
    is PORTC.F0 is PORTC.0 in PICBASIC?
    excuse me for my wrong grammar...
    thanks...
    PBP <>Proteus
    PBP != Proteus
    Which is to say, PBP code is pretty much useless in Proteus and vice versa. This forum is for M E Labs Pic Basic, I am sure there is a Proteus forum if you check Google. If you get the correct compiler to use , I am sure you can get some help here.
    Best Regards,
    JS
    BTW, your grammar needs no excuse, it is quite acceptable.
    Dec 2008
    I use Proton+ PICbasic from Crownhill, I use Proteus ISIS Professional as Simulator...
    Quote Originally Posted by marcasjr View Post
    Proton <> PBP _ Crownhill sponsors their forum too, and also sells that compiler.
    Your Code as posted with my comments in red:
    Device 16F877A
    XTAL = 20   <font color=red> DEFINE OSC 20</font color>
    ALL_DIGITAL = TRUE  <font color=red> Not in PBP
    The following will work but there are better ways.</font color>
    Symbol SO = PORTC.5
    <font color=red> Like . . .
    CS VAR PortC.4
    No Dims in PBP </font color>
    Dim reg as BYTE
    Dim dongu as BYTE
    <font color=red> do it this way
    Dongu VAR BYTE
    Datas VAR BYTE[10]</font color>
    MAX6952_Init:
        PORTC.0=0
    	FOR dongu = 1 to 2
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	PORTC.0=0
    	FOR dongu = 1 to 2
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	PORTC.0=0
    	FOR dongu = 1 to 2
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	PORTC.0=0
    	FOR dongu = 1 to 2
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    max6952_putchar:
        PORTC.0=0
    	FOR dongu = 1 to 2
    	NEXT
    	PORTC.0=1
    	PORTC.0=0
    	TRISC=%010001100
    	Goto MAX6952_Init
    	reg=0x20
    	datas[0]="A"
         Delayms 500<font color=red> Nope! Pause 500</font color>
    Goto main
    That should give you something to chew on a while.
    Wink
    Hi, Marcasjr
    You should switch to the other Crownhill forum, if you want to go on with PROTON ...
    It took me a minute to find it:
    http://www.picbasic.org/forum/
  1. can anyone here can convert this in picbasic pro?
    By reianjim in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 12:43
  2. How to configure SPI in PICBASIC PRO?
  3. Picbasic VS C Compiler
    Last Post: - 11th October 2005, 22:44
  4. Replies: 22
    Last Post: - 12th July 2005, 18:39
  5. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 11:04
