Problems programming
Results 1 to 5 of 5
    They have a windowed version of this PIC that's erased with a UV light source similar to old EEPROMs, but it's pretty expensive.
    If you prefer an 8-pin device, look at some of the newer flash-based parts like the 12Fxxx series. The 12F615 or 12F609 are very inexpensive, and easy to use.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2008
    It is indeed a good device but i don't see the type in Picbasic Pro, so can i program this device?
    I have the chooce between:
    12F508
    12F509
    12F629
    12F675
    12F683
    The chips Bruce mentioned are in PBP 2.50.
    The chips in your list are good too.
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Programming Pins of PICs?
    Last Post: - 15th August 2007, 19:59
  3. PIC16F886 programming problems
    By mmargolis in forum General
    Last Post: - 3rd August 2007, 02:19
  4. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 19:31
  5. ICSP problems
    By Tomexx in forum Off Topic
    Last Post: - 9th January 2006, 00:38
