USB to USB flash Drive File Copier
Results 1 to 40 of 223
    May 2010
    Can Anyone verify when you spark up a vdip module with 5v in fifo mode, attach an flash the led 2 will go on after the alternating led 1 and 2.
    In my case this only happens for the uart mode which programming through hyper terminal/putty is fairy simple.
    I require it in fifo mode though...
    Thx
    I have not tried FIFO and it looks like a waste of MCU pins to me.
    Can I ask why you need to use that mode?
    I also looked through the docs I have and did not see anything that would answer your question about the status LEDs.
    May 2010
    Hi mackrackit,
    I am actually using it with an fpga, but after a chat with the support guys in the US they said don't even bother with fifo on this chip its to flaky, rather stick to uart. FIFO will be upgraded in the 2nd gen ic VN2. So in the mean time i wrote a uart for the fpga and it seems to work.
    Well I could not have done it witout the help of this forum.
    Kind Regards
    Jun 2011
    Default Re: USB to USB flash Drive File Copier
    hi
    can any one post circuit diagram to connect VDIP to PIC ??
    Nov 2009
    read the comments in this thread. and download pdf files from http://www.ftdichip.com/index.html to gain more knowledge about the vdip...goodluck.
    Nov 2009
    sorry about that., this is a better picture
    Nov 2009
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 10:23
