USB to USB flash Drive File Copier
Results 1 to 40 of 223
    California, USA
    That is a difficult one to answer.
    The VDIP requires 5 volts. Four re-chargeable "AA" batteries will give ~4.8 volts, close enough but for how long.
    Be cautious with your battery types here... 4 NiCad AA's will give about 4.8v, but 4 rechargeable ALKALINE AA's can give over 5.6V +
    For linear regulators, these aren't too bad...
    http://ww1.microchip.com/downloads/e...Doc/21991c.pdf
    Only a couple hundred mV dropout voltage, so they work OK on 5 v circuits from a 6v battery.
    You may want to use a switching regulator. Could have one that works with a battery input from 3 to 6 volts, then four "AA" batteries of any type will work. Depending on the circuit the efficiency can be very good.
    If you need to run off a wide supply range, including sucking batteries down "to the last drop" then a good switching supply is THE way to go....
    steve
    Byte_Butcher, Where do you find rechargable ALKALINE AA's ? I have never heard of such a thing.... I'm curious...
    California, USA
    /Cough/ err... well, they do exist, and a quick google search should find you some. But I was MISTAKEN about the ones that I have. I was sure it said Alkaline on the package when I got them, but on closer inspection, these say NiMH on the side of the battery.
    So I guess I meant to say that" 4 rechargeable NiMH AA's can give over 5.6V +" Sorry...
    steve
    What is the brand of the NiMH and AH of the batteries you use?
    The NiMH I use are 1.2 volts at 2500 AH.
    OPPSS!
    That should be 2500 mAh
    California, USA
    Duracell, 2650mAh.
    They're rated at 1.2V, but terminal voltage on a freshly charged one exceeds 1.4V
    steve
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 11:23
