u use the 2.46version...
the code i use it like stuck only can run until the code below then stop
INCLUDE "modedefs.bas"
@ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
DEFINE OSC 20
DEFINE LCD_DREG PORTA 'LCD Data line
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB 'RS bit
DEFINE LCD_RSBIT 5
DEFINE LCD_EREG PORTB 'E bit
DEFINE LCD_EBIT 4
DEFINE LCD_RWREG PORTB 'RW bit
DEFINE LCD_RWBIT 6
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_CHARS 20
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
VinTXD VAR PORTC.7 'AD0 TXD VDIP2 connect RX
VinRXD VAR PORTC.6 'AD1 RXD VDIP2 connect TX
FlowIn VAR PORTC.0 'AD2 RTS
T VAR PORTC.0 'push button
D VAR PORTC.1 ' PUSH BUTTON FOR DISPLAY
X VAR BYTE SYSTEM
Y VAR BYTE SYSTEM
; -- Working with 2D arrays ---
Width CON 8 ; Number of bytes in a Row
Length CON 10 ; Number of Rows in the array
ArraySize CON Width * Length ; Total size of the array
MyArray VAR BYTE[ArraySize] ; The Array
Idx VAR BYTE ; Index, points to 1D array locations
Xidx VAR BYTE ; 2D column Index
Yidx VAR BYTE ; 2D row Index
ArrayData VAR BYTE ; holding register for array data
;----[Get a value from the 2D array]----------------------------------------
Get2D:
Idx=(Yidx*Width+Xidx) MIN (ArraySize-1) ; find Index, limit to ArraySize
ArrayData = MyArray(Idx) ; retrieve value from the array
;----[Put a value in the 2D array]------------------------------------------
Put2D:
MyArray(Idx) = ArrayData ; store the value in the array
;----[Set entire array to 0's]----------------------------------------------
Clear2D:
FOR Idx = 0 TO ArraySize-1
MyArray(Idx) = 0
NEXT Idx
