USB to USB flash Drive File Copier
Results 1 to 40 of 223
    The best I can do is tell you to start a new thread about the 2D array problem. I have not tried them myself.
    Be sure to post your code when you start the new thread...
    Mar 2010
    i already tired to try the 2d array but it still cannot work....
    is that any way to store the file name except using the 2d array?
    If you do not want to post your code and ask about why it does not work I guess there is not much anyone can do to help. You have not even explained exactly what you are trying to do.
    It seems like you now have the VDIP running. So if you want help with arrays or something else start a new thread as suggested.
    Mar 2010
    so sorry,
    i got post my coding..but dunno y cant display...
    now the coding not at me..later i will post again for the coding...thank for your inform
    Mar 2010
    dear sir,
    y when i put the line @Put2D(X,Y) then cannot compile got error
    Error[108] C:\USERS\PIC16F873A\ARRAY TEST 2\ARRAY2.ASM 311 : Illegal character (()
    Mar 2010
    dear mackrackit
    below is my code..it like stuck at some where please help..
    INCLUDE "modedefs.bas"
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
    DEFINE OSC 20
    DEFINE LCD_DREG PORTA 'LCD Data line
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB 'RS bit
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTB 'E bit
    DEFINE LCD_EBIT 4
    DEFINE LCD_RWREG PORTB 'RW bit
    DEFINE LCD_RWBIT 6
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_CHARS 20
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    VinTXD VAR PORTC.7 'AD0 TXD VDIP2 connect RX
    VinRXD VAR PORTC.6 'AD1 RXD VDIP2 connect TX
    FlowIn VAR PORTC.0 'AD2 RTS
    T VAR PORTC.0 'push button
    D VAR PORTC.1 ' PUSH BUTTON FOR DISPLAY
    X VAR BYTE SYSTEM
    Y VAR BYTE SYSTEM
    ; -- Working with 2D arrays ---
    Width CON 8 ; Number of bytes in a Row
    Length CON 10 ; Number of Rows in the array
    ArraySize CON Width * Length ; Total size of the array
    MyArray VAR BYTE[ArraySize] ; The Array
    Idx VAR BYTE ; Index, points to 1D array locations
    Xidx VAR BYTE ; 2D column Index
    Yidx VAR BYTE ; 2D row Index
    ArrayData VAR BYTE ; holding register for array data
    ;----[Get a value from the 2D array]----------------------------------------
    Get2D:
    Idx=(Yidx*Width+Xidx) MIN (ArraySize-1) ; find Index, limit to ArraySize
    ArrayData = MyArray(Idx) ; retrieve value from the array
    ;----[Put a value in the 2D array]------------------------------------------
    Put2D:
    MyArray(Idx) = ArrayData ; store the value in the array
    ;----[Set entire array to 0's]----------------------------------------------
    Clear2D:
    FOR Idx = 0 TO ArraySize-1
    MyArray(Idx) = 0
    NEXT Idx
    ;----[Turn the Subroutines into Functions]----------------------------------
    #Get2D macro X, Y
    MOVE?BB X, _Xidx ; copy users X value to Xidx
    MOVE?BB Y, _Yidx ; copy users Y value to Yidx
    L?CALL _Get2D ; call the Get subroutine
    endm ; value is returned in ArrayData
    #define Get2D(X, Y) #Get2D X, Y ; allows paretheses in macro
    #Put2D macro X, Y ; value should be in ArrayData
    L?CALL _Put2D ; call the Put subroutine
    #define Put2D(X, Y) #Put2D X, Y ; allows paretheses in macro
    #Clear2D macro
    L?CALL _Clear2D ; call the Clear subroutine
    #define Clear2D() #Clear2D
    ;a var BYTE[12]
    FILE1 VAR BYTE[12]
    FILE2 VAR BYTE[12]
    FILE3 VAR BYTE[12]
    ;X VAR BYTE
    CRET VAR BYTE
    CRET = $0D
    StartDisk:
    pause 3000
    HIGH VinRXD
    SEROUT2 VinRXD,84,["ECS",13]
    LCDOUT $FE,1, "1"
    PAUSEUS 1000
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,84,["IPA",13]
    LCDOUT $FE,1, "2"
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,84,["A:",13]
    LCDOUT $FE,1, "3"
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,84,["DIR",13]
    LCDOUT $FE,1, "4"
    PAUSEUS 1000
    WAIT1
    IF FLOWIN = 1 THEN WAIT1
    SERIN2 VinTXD,84,[WAIT(CRET),STR FILE1\12 \CRET]
    LCDOUT $FE,1, "5"
    @ Clear2D ; clear the array
    FOR Y = 0 TO Length-1 ; fill the array with data
    FOR X = 0 TO Width-1
    ArrayData =FILE1[X] ; value to put in array
    @ Put2D(X,Y)
    NEXT X
    NEXT Y
    PAUSE 1000
    @ Get2D(X,Y)
    NEXT X
    LCDOUT $FE,1,ArrayData
    NEXT Y
    goto StartDisk
    So you got the new version of PBP?
    Where did you get it?
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 11:23
