USB to USB flash Drive File Copier
Results 1 to 40 of 223
    The first thing we need to do is make sure the PIC is running at the speed you think it is, or know what speed it is running at.
    These USB chips can be confusing ( for me anyways ) when it comes to setting the PLL and all. Bruce has a good explanation here that I refer to.
    http://www.picbasic.co.uk/forum/show...85&postcount=4
    So if you set the configs as he has them the PIC should be running at 48MHz.
    DEFINE OSC 48
    To check the speed write a code that will blink an LED at one second on and one second off.
    Then refer to the PBP manual under SEROUT2. There it shows how to connect the chip to a PC. Send some text to a terminal.
    When this is all working we can "talk" to the VDIP.
    Mar 2010
    for me also confuse for that part...so i change the pic 18f4550 to pic16f873A..this will more easy (i think)...now i try make it working on hyperterminal ....
    Mar 2010
    i still cannot display on the hyperterminal...still got any solution?
    Darn...
    Check the pick with a one second blink to see if it is running at the expected speed?
    Using a 232 type chip between PIC and PC?
    Post the exact code and configs you are testing with.
    Maybe we will see some thing.
    Mar 2010
    i testing with the code i post b4..i got connect to 232 using max232..i already test the mode with 84,8276
    INCLUDE "modedefs.bas"
    DEFINE OSC 20
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 4
    DEFINE LCD_RWREG PORTB
    DEFINE LCD_RWBIT 6
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    TXD VAR PORTC.7 'AD0 TXD VDIP2 connect RX
    RXD VAR PORTC.6 'AD1 RXD VDIP2 connect TX
    Flow VAR PORTC.0 'AD2 RTS
    Start:
    HIGH RXD
    PAUSEUS 10
    SEROUT2 RXD,84,["ECS",13]
    HIGH RXD
    PAUSEUS 10
    SEROUT2 RXD,84,["IPA",13]
    HIGH RXD
    PAUSEUS 10
    SEROUT2 RXD,84,["A:",13] 'choose source disk
    HIGH RXD
    PAUSEUS 100
    SEROUT2 RXD,84,["DIR",13]
    GOTO Start
    I would like to see you test a simple "hello world" to the PC without the VDIP involved.
    At this point we do not know where the problem is. Need to narrow it down.
    Mar 2010
    i did not connect to the VDIP..just connect with max232...
    HIGH RXD
    and i change to
    HIGH RXD
    SEROUT2 RXD,84,["hello",13]
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 11:23
