Quote Originally Posted by newbie View Post
what this does is select drive A: of the vdip2. i used this because the vdip2 swiches to the drive where a flash drive is last inserted so just to make sure in case a drive is last inserted to drive B:, the vdip2 would still go back to port A:. I'm doing this because i want to set drive A: as the source drive and B: as the target drive.
OK, that is why I did not know, it is for the VDIP2.
You code loops back to "StartDisk:". Does the firmware version show up all of the time of just on the first time trhough?
