INCLUDE "modedefs.bas"
DEFINE LCD_DREG     PORTC
DEFINE LCD_DBIT     0
DEFINE LCD_RSREG    PORTD
DEFINE LCD_RSBIT    2
DEFINE LCD_EREG     PORTD
DEFINE LCD_EBIT     1
DEFINE LCD_RWREG    PORTD
DEFINE LCD_RWBIT    0
DEFINE LCD_BITS     8
DEFINE LCD_LINES    4
Define LCD_CHARS    20
DEFINE LCD_COMMANDUS    2000
DEFINE LCD_DATAUS   50
VinTXD VAR PORTD.4 'AD0
VinRXD VAR PORTD.3 'AD1
FlowIn VAR PORTD.5 'AD2
Pause 500
FILE1 VAR BYTE[12]
FILE2 VAR BYTE[12]
FILE3 VAR BYTE[12]
X1	VAR	BYTE
X2	VAR	BYTE
X3	VAR	BYTE
X4	VAR	BYTE
X5	VAR	BYTE
X6	VAR	BYTE
X7	VAR	BYTE
X8	VAR	BYTE
X9	VAR	BYTE
X10	VAR	BYTE
X11	VAR	BYTE
X12	VAR	BYTE
X13  VAR	BYTE
X14  VAR	BYTE
X15  VAR	BYTE
X16  VAR	BYTE
X17  VAR	BYTE
X18  VAR    BYTE
X19  VAR	BYTE
X20  VAR	BYTE
X21  VAR	BYTE
X22  VAR	BYTE
X23  VAR	BYTE
X24  VAR	BYTE
X25  VAR	BYTE
X26  VAR	BYTE
X27  VAR	BYTE
X28  VAR	BYTE
X29  VAR	BYTE
X30  VAR	BYTE
X31  VAR	BYTE
X32  VAR	BYTE
X33  VAR	BYTE
X34  VAR	BYTE
X35  VAR	BYTE
X36  VAR	BYTE
CRET VAR BYTE
CRET = $0D
StartDisk:
HIGH VinRXD
PAUSEUS 1000
SEROUT2 VinRXD,8588,["ECS",13]
LCDOUT $FE,1, "1"
HIGH VinRXD
PAUSEUS 1000
SEROUT2 VinRXD,8588,["IPA",13]
LCDOUT $FE,1, "2"
HIGH VinRXD
PAUSEUS 1000
SEROUT2 VinRXD,8588,["A:",13]
LCDOUT $FE,1, "3"
HIGH VinRXD
PAUSEUS 100
SEROUT2 VinRXD,8588,["DIR",13]
LCDOUT $FE,1, "4"
PAUSEUS 1000
WAIT1
IF FLOWIN = 1 THEN WAIT1
SERIN2 VinTXD,8588,[WAIT(CRET),STR FILE1\12 \CRET,WAIT(CRET),STR FILE2\12 \CRET,WAIT(CRET),STR FILE3\12 \CRET]
LCDOUT $FE,1, "5"
X1 = FILE1[0]
X2 = FILE1[1]
X3 = FILE1[2]
X4 = FILE1[3]
X5 = FILE1[4]
X6 = FILE1[5]
X7 = FILE1[6]
X8 = FILE1[7]
X9 = FILE1[8]
X10 = FILE1[9]
X11 = FILE1[10]
X12 = FILE1[11]
X13 = FILE1[0]
X14 = FILE1[1]
X15 = FILE1[2]
X16 = FILE1[3]
X17 = FILE1[4]
X18 = FILE1[5]
X19 = FILE1[6]
X20 = FILE1[7]
X21 = FILE1[8]
X22 = FILE1[9]
X23 = FILE1[10]
X24 = FILE1[11]
X25 = FILE1[0]
X26 = FILE1[1]
X27 = FILE1[2]
X28 = FILE1[3]
X29 = FILE1[4]
X30 = FILE1[5]
X31 = FILE1[6]
X32 = FILE1[7]
X33 = FILE1[8]
X34 = FILE1[9]
X35 = FILE1[10]
X36 = FILE1[11]
PAUSE 100
LCDOUT $FE,1,X1,X2,X3,X4,X5,X6,X7,X8,x9,x10,x11,x12
LCDOUT $FE,$C0,X13,X14,X15,X16,X17,X18,X19,X20,X21,X22,X23,X24
LCDOUT $FE,$94,X25,X26,X27,X28,X29,X30,X31,X32,X33,X34,X35,X36
PAUSE 2000
goto StartDisk
Here is the code..i haven't been able to add other functions yet because im still addressing to the problem that i stated earlier..
oh and one more question, is it really necessary to save the the array values into another byte like for this instance the x's? cant i directly use these array values to be printed to the LCD?
