USB to USB flash Drive File Copier
Results 1 to 40 of 223
    If the file names are always the same, you could assign them each a number, and store the names in eprom, or if they have all the same name with a number, even easier, just display the name followed by the number received. Unless I am missing something due to inadequate supply of coffee .
    You might try what Joe suggested before and pre-populate the arrays with a known value.
    Nov 2009
    here is the rule about the files from the vinculum:
    Filenames are made up of an 8 character main part and an optional 3 character extension. The presence of a ’dot’ character in the filename indicates the boundary between the main part and the extension. The name may be up to 12 characters long, including the ‘dot’ character.
    can you give me a sample code about this? I'm not that familiar with eproms.
    ive been thinking about doing that..but the thing is if the length of the file names is less than 12, i might have trouble retrieving only the arrays that were inserted with the file name characters. if i include the arrays that were not over written by the file name characters and still contains the pre loaded value, the vdip2 would respond "command failed".
    Quote Originally Posted by newbie View Post
    What if you populate the array with a character that would probably not be used in a file name, (~), and parse the array for that before the array is used again.
    Or, have a "working" array. This would be one that stored arrays are parsed into for using.
    Stored array with (~) character
    Stored array re-written into sandbox array
    Sandbox array is sent to VDIP
    Start over with next stored array.
    Maybe....
    Nov 2009
    Maybe....
    are saying its like this:
    say you have an array named FILE1 with 12 array places, i will pre-load it with (~) so...
    FILE1 = [~][~][~][~][~][~][~][~][~][~][~][~]
    and then when i receive a file named "vdip.txt" from the vdip serially, then the array would be like:
    FILE1 = [v][d][i][p][.][t][x][t][~][~][~][~]
    am i right with this? please correct me if im wrong...
    then when i want to send command to the vdip that i want to copy that particular file, i will be sending the "CPS" command plus the array of bytes stored in FILE1 including the bytes that contains [~] back to the vdip, but the vinculum is very strict with the spelling...if i include these bytes it will respond with "command failed" if only i could remove those unneeded bytes before sending it back to the vdip...
    am i getting your idea right?
    Thinking more about this the "~" will not do you any good. Still need to re-write the array but...
    Assume file names should only contain letters and numbers. The problem is other characters are showing up..
    So when the file name is read from the VDIP say it is saved into "arrayF". Before "arrayF" is used again it needs checked for bad characters. Right?
    Again have a working array that will be used and/or reused to send back to the VDIP, "arrayW".
    The bad characters are at the end of the name?
    What if you check each bit of "arrayF" and IF the bit equals A-Z or 0-9 then that bit will be written to "arrayW". When the first bad character bit is found the re-write loop stops.
    Now "arrayW" should only contain valid characters.
    This thread should give you some ideas on how to process the arrays.
    http://www.picbasic.co.uk/forum/showthread.php?t=8876
    I hope this is on the correct track.
    Nov 2009
    this is so unfortunate..my vdip2 is suddenly not working...
    the status LEDs do not light when i turn the circuit on.. it also does not respond when i insert flash drives...
    i tried connecting it to the pc's serial port to see if the LEDs are just busted, but nothing happend. its as if there's nothing connected to the serial port.
    i've measured the voltage supplied and i saw that the voltage was correct.
    did anyone experience this? can there still be a remedy for this module?
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 11:23
