USB to USB flash Drive File Copier
Results 1 to 40 of 223
Threaded View
  1. #22
    Nov 2009
    line feed is 10 right? if i would have the line feed to an IF statement, how would i get the compiler to understand that I am pertaining to 10 as the line feed and not the number itself? would i need to put a preceding sign like # or $ or should i just put 10 without the "" marks?
    Just have the string terminate when EOF is returned.
    are you talking about the array of bytes as the string in here? or is there a way to save the group of characters into one string constant?
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 10:23
