USB to USB flash Drive File Copier
Results 1 to 40 of 223
    Re-read this.
    http://www.picbasic.co.uk/forum/showthread.php?t=7700
    Post your current code and a schematic.
    Nov 2009
    INCLUDE "modedefs.bas"
    DEFINE LCD_DREG     PORTB
    DEFINE LCD_DBIT     0
    DEFINE LCD_RSREG    PORTD
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTD
    DEFINE LCD_EBIT     3
    DEFINE LCD_RWREG    PORTD
    DEFINE LCD_RWBIT    2
    DEFINE LCD_BITS     8
    DEFINE LCD_LINES    4
    Define LCD_CHARS    20
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    VinTXD VAR PORTC.7 'AD0
    VinRXD VAR PORTC.6 'AD1
    FlowIn VAR PORTC.5 'AD2
            Pause 500       ' Wait for LCD to startup
    mainloop:
    		Lcdout $fe, 1,  "********************"
            Lcdout $fe,$C0, "   PORTABLE FILE    "
    		Lcdout $fe,$94, "  TRANSFER DEVICE   "
    		Lcdout $fe,$d4,	"********************"
            Pause 3000       ' Wait 2 secondS
    NUMS	VAR	BYTE[16]
    X1	VAR	BYTE
    X2	VAR	BYTE
    X3	VAR	BYTE
    X4	VAR	BYTE
    X5	VAR	BYTE
    X6	VAR	BYTE
    X7	VAR	BYTE
    X8	VAR	BYTE
    X9	VAR	BYTE
    X10	VAR	BYTE
    X11	VAR	BYTE
    X12	VAR	BYTE
    StartDisk:
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,8588,["ECS",13]
    LCDOUT $FE,1, "1"
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,8588,["IPA",13]
    LCDOUT $FE,1, "2"
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,8588,["A:",13]
    LCDOUT $FE,1, "3"
    HIGH VinRXD
    PAUSEUS 100
    SEROUT2 VinRXD,8588,["DIR",13]
    LCDOUT $FE,1, "4"
    PAUSEUS 1000
    WAIT1
    IF FLOWIN = 1 THEN WAIT1
    SERIN2 VinTXD,8588,[STR NUMS\12]
    LCDOUT $FE,1, "5"
    X1 = NUMS[0]
    X2 = NUMS[1]
    X3 = NUMS[2]
    X4 = NUMS[3]
    X5 = NUMS[4]
    X6 = NUMS[5]
    X7 = NUMS[6]
    X8 = NUMS[7]
    X9 = NUMS[8]
    X10	= NUMS[9]
    X11	= NUMS[10]
    X12	= NUMS[11]
    PAUSE 100
    LCDOUT $FE,1,X1,X2,X3,X4,X5,X6,X7,X8,x9,x10,x11,x12
    PAUSE 2000
    goto StartDisk
    here is my code. its almost the same as the one that i posted earlier..
    i changed the baud rate back to 8588 in the program and tried to change the vdip's baud rate to 4800 in the comport monitor using the SBD $710200 (change baud rate to 4800) command but the monitor just printed weird characters and then the comport monitor stopped responding. When i restarted the connection, the vdip was still working properly in 9600 baud rate and not in 4800.
    i also tried to change the baud rate of the vdip using a newly modified firmware with 4800 set as its baud rate. I saved it in a flash drive and inserted it to the vdip but when I entered the command FWU ftrfb.ftd (firmware upgrade ftrfb.ftd), the monitor printed "No Upgrade". obviously that was a failure.
    I haven't made a circuit diagram yet since im still testing with breadboards. I do have a working PIC development board where i interfaced the lcd and the vdip..here are the pin connections.
    LCD DATA LINES - PORTB
    LCD RS BIT - PORTD.1
    LCD RW BIT - PORTD.2
    LCD E BIT - PORTD.3
    VinTXD(AD0) - PORTC.7
    VinRXD(AD1) - PORTC.6
    RTS(AD2) - PORTC.5
    CTS(AD3) - GND
    OSC 4MHZ
    I had a little extra time so I dug out my VDIP1.
    Where to start...
    I see you are running the PIC at 4Mhz so 9800 baud may be a bit fast so lets work with 4800 baud.
    We need to get your VDIP working at 4800, 8, N, 1.
    The zip file attached has FTRFB.FTD in it. Unzip the zip and put the FTD file on a blank USB stick. The VDIP should see this file and do a firm ware upgrade. You do not need to send any commands at this point.
    I have the VDIP1 connected to a terminal to see what is going on.
    VDIP connections:
    PIN1 = 5VOLT
    PIN6 = PIN11 on a MAX232 PIN14 on the MAX goes to PC serial PIN2
    PIN7, 10, and 18 = GROUND (ZERO VOLTS)
    You can take PIN22 LOW to reset the VDIP1
    A screen shot of the VDIP running at 9800 changing to 4800.
    And a screen shot of the VDIP running at 4800 rebooted to the same USB stick.
    I will try to get more time later this weekend to play some more.
    Nov 2009
    does the serial communicator automatically change the firmware at the start of the connection? no need to enter any commands?
    To upgrade the firmware you do not need to send any commands. If the VDIP sees a new firmware it will upgrade to it. When a new firmware is "built" a three character ID is given to it. The ID is whar the VDIP looks at.
    The firmware I gave you has NE1 as the ID. If the ID is the same the VDIP will return "No Upgrade".
    Go down to post #19 here.
    http://www.picbasic.co.uk/forum/show...3888#post83888
    Nov 2009
    I use the hyper terminal for serially communicating the vdip to the rs232. ive attached the level converter circuit that i used here in this post. you might as well take a look at it and see if it differs from the one that you know. that circuit worked very well when i used the hyper terminal but when I tried to use the microcode's serial communicator, it didn't respond to anything that i did. i reconfigured the circuit according to you pin assignments but the results were the same. does this have anything to do with me using vdip2 and you using vdip1? but then im pretty sure that i carefully reassigned the pins in the vdip2 that are equivalent to the vdip1.
    since microcode's serial communicator does not work for me, i switched back to hyper terminal but when i inserted the flash disk with the new firmware in it(with a different 3 letter ID), it did not detect any upgrade. so i was forced to use the command used for upgrading the firmware. I typed in FWU FTRFB.FTD. after that it prompted:
    ChangeMAINTD
    Reflasher Active
    Rebooting
    for a moment i look like the one in your printscreen but then after a few seconds it displayed the previous firmware with the previous firmware ID and the vdip2 was still working at 9600 baud rate. Ive also attached the printscreen of that event in this post. you may see it for yourself.
    what can you say? should i stop trying to change the vdip2's baud rate and make the pic micro controller adapt to it instead?
    I this point I would say yes, run at 9600. I do not have a VDIP2 to test so I am at a loss.
    9600 normally requires an OSC faster than 4Mhz though.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 11:23
