USB to USB flash Drive File Copier
Results 1 to 40 of 223
    Cool!!! You are making progress.
    I did not play with sub directories much, I was just writing file to the root directory. But I do remember trying it.
    Are you using the Extended Command Set with your firmware?
    Looking at the
    Vinculum Firmware User Manual
    Version: 2.3
    Issue Date: 2007-12-03
    On page 30 section 6.2.1 Directory (DIR)
    This statement is made:
    Note that if the specified file is a directory, a size of zero will be displayed rather than a listing of the files in that directory.
    So maybe you are there and do not know it???
    Nov 2009
    I should thank you because you shared your knowledge with me that's why my project is developing. However, knowing the note from the firmware really hurt my feelings. how will i ever manipulate the file names for the file transfer if i cannot view them? Ive read in one of their manuals that the vdip can go down to 16 sud directories, how can they say that if they would only print zeroes?
    Quote Originally Posted by newbie View Post
    Are you saying that I hurt your feelings?
    I only ran across that note about five minutes before I posted it after looking through the manual for clues to your problem.
    If I knew how to do what you are wanting I would gladly tell you how.
    After you receive the zeros, what happens if you send another DIR command?
    The manufacturer also has tech support if all else fails.
    Nov 2009
    oh no you got me misunderstood.. that just meant that i think I'm in a little bit of a trouble not being able to view the sub directories. I will ask the vinculum's customer support about this matter, and for the mean time i will be concentrating on the files located on the root..i wasn't successful the first time i interfaced the vdip2 to the pic16f877a. I could not get any response from the vdip. all i get are weird characters printed in the lcd even when the vdip is turned off. have you encountered this?
    OK. I get what you mean.
    Contact teck support and see what they say.
    In the mean time post your code and configs along with a schematic here and maybe if we are lucky someone will see the problem.
    Nov 2009
    DEFINE OSC 20
    INCLUDE "modedefs.bas"
    DEFINE LCD_DREG     PORTC
    DEFINE LCD_DBIT     0
    DEFINE LCD_RSREG    PORTD
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTD
    DEFINE LCD_EBIT     3
    DEFINE LCD_RWREG    PORTD
    DEFINE LCD_RWBIT    2
    DEFINE LCD_BITS     8
    DEFINE LCD_LINES    4
    Define LCD_CHARS    20
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    VTXD VAR PORTB.0
    VRXD VAR PORTB.1
    Flowin VAR PORTB.2
            Pause 500
    	Lcdout $fe,$C0, " Please Insert Your "
            Lcdout $fe,$94,	 "    Flash Drive        "
            Pause 100
    RESP	 VAR	 BYTE[16]
    X1	VAR	BYTE
    X2	VAR	BYTE
    X3	VAR	BYTE
    X4	VAR	BYTE
    X5	VAR	BYTE
    X6	VAR	BYTE
    X7	VAR	BYTE
    X8	VAR	BYTE
    checkvin:
    SEROUT2 VRXD,8588,["ECS",13]
    HIGH VRXD
    PAUSEUS 10
    SEROUT2 VRXD,8588,["IPA",13]
    HIGH VRXD
    PAUSEUS 10
    WAIT1
    IF Flowin = 1 THEN WAIT1
    SEROUT2 VRXD,8588,["DIR",13]
    PAUSE 100
    SERIN2 VTXD,8588,[STR RESP\8]
    X1 = RESP[0]
    X2 = RESP[1]
    X3 = RESP[2]
    X4 = RESP[3]
    X5 = RESP[4]
    X6 = RESP[5]
    X7 = RESP[6]
    X8 = RESP[7]
    X9 = RESP[8]
    X10 = RESP[9]
    X11 = RESP[10]
    X12 = RESP[11]
    PAUSE 100
    LCDOUT $FE,1,X1,X2,X3,X4,X5,X6,X7,X8,X9,X10,X11,X12
    PAUSE 2000
    As you can see I ripped a part of your code. pardon me for doing so. I just wanna see if the vdip would respond to the pic. This program is pretty short, I just wanted to display the first file it detects to the lcd. I wouldn't want to write a long program and then start wondering what part of the code went wrong after wards. Once I get a response even just one file name from the directory then will start to write my own program including the file browsing.
    Nov 2009
    I can now view the files in the sub directories...this is my bad.. I was entering DIR (file), this command would only list the specified file and size. I did not see until now that these was another command that will change the current directory, its CD (folder). my bad sorry. now i can go on and make a program once i get responses from the vdip with the pic controlling it.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 11:23
