Quote Originally Posted by newbie View Post
please correct me if i'm wrong,
i will burn the program to the pic, then, i will connect the pic to the vinculum using uart mode. then the pic will be the one to issue commands to the vinculum and there is no need for the 232 connections. is that right?
also, how i'm i going to apply the vinculum command sets such as WRF and CLF ? will the compiler be able to understand them?
Have you read the code examples posted here? How to read and write are both here.
As for a compiler, PBP is the only one I will recommend.
Practice blinking LEDs with the demo version and other small things first. Then try something bigger later.
You will not be able to make this work as a first project even if you had the full version of PBP.
