frequency detector
Results 1 to 9 of 9
    Aug 2005
    down south
    Talking
    think to you both.
    I'm a little green this stuff and have never used the comparators part of these
    little big boy toys. (and gals) so I will start learning what I can. if there is anything that yo care to share on the matter I'm all ears.
    I'm just a hobbyist and enjoy learning from this forum and I'm trying hard not to be a pain in the butt.
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    timmers's Avatar
    timmers Guest
    The PIC lives in a digital world where evrything is between 0v and 5v. Video lies in the analogue world, a strange and wonderful world it is too... But everything in analogue video does not live within the 0v to 5v parameter.
    Video feeds are often AC coupled through a capacitor and require an amplifier and a DC clamp circuit before they can be sampled. Easiest way to interface to video is to use a dedicated sync seperator which can perform all the analogue processing and output into the digital domain. Take a look at National LM1881 for example.
    PAL video sync is 300mV with the video sitting a further 700mV above that. Total amplitude is 1v peak to peak. The sync is a composite sync containing short pulses for line sync, longer pulses for frame sync and equalising pulses between the two. There is a good description of video sync structure in the LM1881 data sheet.
    Tim.
    Aug 2005
    down south
    thanks
    so it data sheet, Google and print PDF time.
    like I said using the NE567 work fine just thinking it would be easy todoall with 12f629 but look a lot more than I thought
    any search tips?
    thanks as always
    fronkensteen's Avatar
    fronkensteen Guest
    Quote Originally Posted by grounded View Post
    thanks
    any search tips?
    thanks as always
    You want just the 15.75Khz signal and you're trying to count just that 15.75Khz signal to detect the presence of a video signal.
    One of the problems is the fact that there's a lot more going on than just that 15.75Khz signal, so you're probably counting a heck of a lot more than just that.
    Maybe add a fairly tight bandpass filter in front of your input/amplifier and see what happens.
    Mostly though I think I would put an o-scope on the input pin and see what you actually looking at.
  1. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 23:41
  2. HPWM10 Frequency Updating
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 13:30
  3. How do I convert an internal variable into frequency
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 13th February 2007, 08:26
  4. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 17:22
  5. frequency measurement
    By big-x in forum General
    Last Post: - 25th November 2005, 01:53
