16f887 44 pin demo board code problem?
Results 1 to 10 of 10
    Quote Originally Posted by jessey View Post
    Even though the program worked good using _INTRC_OSC_NOCLKOUT I changed it to _INTRC_OSC_CLKOUT, am I right in doing that
    In CLKOUT mode you can send a clock pulse signal out to another device.
    NOCLKOUT you can use the pins for I/Os
    and also is there a way for me to verify that the program is running on 4 MHz without using an oscilloscope?
    Program a simple blinky with one LED that will blink at a certain rate. If you code has
    and the chip is running at 4MHz, then the LED will blink at the correct rate.
    jessey's Avatar
    jessey Guest
    Thanks Dave,
    I added the code below in the MainLoop to check out your explanation and I can see that the timing is correct at 4 MHz and runs twice as fast at 8 MHz, that's cool!
       IF Push_Button = Is_Pressed THEN
          OSCCON = MHz8
          OSCCON = MHz4
    jessey
    jessey's Avatar
    jessey Guest
    Hello,
    I was wondering if someone could suggest why this code below doesn't work to change the oscillator speed of the Internal Oscillator while the program is running but the other code block below does work? Another thing I was pondering is, shouldn't I be setting bit 0 of the OSCCON register to 1? The datasheet for the 16f887 says this about bit 0:
    1 = Internal oscillator is used for system clock
    0 = Clock source defined by FOSC<2:0> of the CONFIG1 register.
    'this doesn't work
          IF OSCCON = %01100000 THEN
             OSCCON = %01110000
             OSCCON = %01100000
          WHILE Push_Button = Is_Pressed
               PORTD = %10000001 ' Show that button press has stopped the code here
          WEND
    'this works
          IF B = 0 THEN
             B = 1
             B = 0
          WEND
       IF B = 0 THEN OSCCON = %01110000 ' 8 MHz
       IF B = 1 THEN OSCCON = %01100000 ' 4 MHz
    jessey
    Lightbulb
    hi,
    I think it is "not so good" to change osc settings WHILE you touch the button ( debounce issue guaranteed !!! ...PORTD can show anything but truth !!! )
    good reason for #2 to work better ... ONLY better.
    I ( it's me ...) Would look for button state CHANGES instead of simply the button state ...
    See post #4
    You have the OSC set for internal at the start. In the config settings. You do not need to change the source.
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Making Program Code Space your playground...
  3. Help with 18F4520 on PICDEM 2 Plus Demo Board 2006
    By kennYy in forum mel PIC BASIC
    Last Post: - 28th April 2008, 17:12
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  5. SRF04 Range Finder 16F628 R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 03:08
