I really appreciate you guys trying to help. The code that you see on my previous post makes the leds blinks, both porta.0 and portd.0. I do not know about other pics, but on the 18F4620 the port is digital as per the datasheet. If you want to use for ADC, then you must specify it on code. It is on chapter 19 of the datasheet. Again, the code works 100% when I use the Basic editor on the simulator or if I use assembler. I only use the basic editor of the simulator to write the code and create the hex file to then burn it on the chip.
My point is, when I use MicroCode Studio to write code and I want to pass it to my chip, the code does not work. In other words, the leds do not blink. I think there might be something wrong or I am doing something wrong on my code.
