problem with asm interrupt
Results 1 to 6 of 6
    servo260's Avatar
    servo260 Guest
    Default problem with asm interrupt
    I'm trying to use asm interrupts in pbp but I have the following problem:
    the interrupt works fine, but the main program works at "half" if that makes sense, it only run a part of the main program while doing the interrupt.
    here is the simple code i'm using to test it:
    define osc 20
    clear
    pulsos var word
    x var word
    num var byte
    wsave var byte $20 system
    ssave var byte bank0 system
    psave var byte bank0 system
    TRISA = %11111111 ; configura el puerto A como salida
    TRISB = %10000000 ; configura los puertos B0-6 como salida
    goto start ; salta al programa principal antes que la interrupcion
    define INTHAND display ; indica cual es la interrupcion
    start:
    option_reg = %00000111
    intcon = %10100000
    x = 123
    x = 321
    asm
    display movwf wsave ; display rutine
    swapf STATUS, W
    clrf STATUS
    movwf ssave
    movf PCLATH, W
    movwf psave
    endasm
    num = x dig 0
    portb = num
    high portb.4
    pauseus 50
    low portb.4
    num = x dig 1
    portb = num
    high portb.5
    pauseus 50
    low portb.5
    num = x dig 2
    portb = num
    high portb.6
    pauseus 50
    low portb.6
    asm
    bcf INTCON, 1
    movf psave, W
    movwf PCLATH
    swapf ssave, W
    movwf STATUS
    swapf wsave, F
    swapf wsave, W
    retfie
    endasm
    the problem is I only get to see the 123.
    If someone knows how to solve this please help me.
    Thanks.
    servo260's Avatar
    servo260 Guest
    I have change the bcf INTCON.1 to INCON.2 but it is still not working.
    At 20MHz with a TMR0 prescaler of 1:256 you only have 13mS before TOIF will be set again, and generate the next interrupt.
    You're using 500mS delays in main with a 13mS TMR0 interrupt time. Try a delay time shorter than your interrupt time, or save & restore the registers used to hold the delay value, or insert your long delay within the body of the interrupt routine.
    You can delay inside the interrupt routine as long as you like before the RETFIE, but I would reload TMR0 with 0 before resetting TOIF.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    servo260's Avatar
    servo260 Guest
    Thanks, though, it is still not eorking.
    How do I save & restore the registers used to hold the delay value? ; what do I have to save in order to continue whatever thing the program was doing?
    I'm new with pics and pbp.
    Post
    You're using Basic statements in your Assembler interrupt. That's a big nono unless you save and restore PBPs workingregisters. Looking at the compiled code it seems that R0 through 3 is used. Try adding ......
    r0save = R0
    r1save = R1
    r2save = R2
    r3save = R3
    ...... directly after your first ASM block, and ........
    R0 = r0save
    R1 = r1save
    R2 = r2save
    R3 = r3save
    .... right before your second ASM block.
    You should also declare your new variables at the top of your program .......
    r0save VAR WORD bank0
    r1save VAR WORD bank0
    r2save VAR WORD bank0
    r3save VAR WORD bank0
    /Ingvar
    servo260's Avatar
    servo260 Guest
    Thanks, everithing is working fine.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. 18F2480 asm interrupt
    By Richard Storie in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:40
  3. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 02:34
  4. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
  5. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
