I can't get the HSERIN to work on simple PIC asynchronous transmit and recieve
*Running at 115200bps
(using 22.1184MHz xstal, for 0%error baud rate)
*transmitter is a PIC18F252
*reciever is a PIC18F252
Transmitter:
'HARDWARE DECLARATIONS (defines and port settings)
Define OSC 20 '0% baud error with 22.1184Mhz xstal
Define HSER_RCSTA 90h 'PIC Hardware Serial Port Receiver define
Define HSER_TXSTA 24h 'PIC Hardware Serial Port Transmit
define HSER_SPBRG 11 'Zero error SPBRG integer value
define ADC_BITS 8 '8 bit sampling ADC define
define ADC_SAMPLEUS 5 'Analog data sample time
TRISA = 255 'Set PORTA to all input
ADCON1 = 0 'PORTA set to analog use for ADC
'VARIABLES
wilma var byte '[3] 'Variable for Accelerometer data
I var byte 'Variable for counter label
'PROGRAM
i = 0
wilma = 0
Pause 5000
Start:
ADCIN 0, wilma'
wilma=(wilma*3)-50
hserout [wilma]
pause 10
goto Start
Reciever:
Define OSC 20
Define HSER_TXSTA 24h 'PIC Hardware Serial Port Transmit using "20h"
'VARIABLES
Fred Var byte
'PROGRAM
Start:
hserin [bin Fred] 'Hardware Rx Pin C.7 (pin #18) on PIC18F252
hpwm 1, Fred, 20000 'Hardware HPWM Pin CCP1 (pin #13) on PIC18F252
goto start
