8+8 IOs controlled via sms
Results 1 to 16 of 16
    May 2008
    Italy
    Thank you Joe S., thank you Peter, for your input.
    Al.
    Turkey
    0XXXYYYYYYY (11 digits with zero)
    X --> Operator (3 digits)
    Y --> phone number (7 digits)
    The country codes are not used, if the call is not international.
    GurkaN
    izmir - Turkey
    May 2008
    Italy
    GurkaN, thank you for the contribution to design a global map of cellphone calling system.
    Al.
    Dec 2007
    Cd. Juarez, Mexico
    Here the info for Mexico:
    xxx yyyyyyy
    xxx = area code
    yyyyyyy = phone number
    May 2008
    Italy
    Thank you Norbac, for the input.
    Al.
    fronkensteen's Avatar
    fronkensteen Guest
    http://communication.howstuffworks.c....htm/printable
    All sorts of information. Another search for the E.164 standard is revealing also. Lots of standards, so little code space.
    Mar 2006
    Pennsylvania, USA.
    Hi Al,
    I did something like this three years ago, using a Multi-Tech modem for CDMA networks. (CDMA is popular here in the US, most of Europe is GSM.) I allocated an array with ten bytes, three for the area code, and seven for the mobile telephone number. On our network you don't have to dial a 1 first, but other networks might require it. When a user sent an SMS message in to the system they had to have a command and a four digit password in the body of the message. Then the system sent back a response to the phone number that came in on their message, in the caller id header.
    If the command wasn't valid, or the password wasn't valid then it sent back a message to that effect.
    If you'd like to see it I can post the code, but it will take me a day or so to find it, it's on a back up disk somewhere.
    Jerry.
  1. Replies: 11
    Last Post: - 19th August 2009, 16:23
  2. HELP ME, SMS controlled relay using PIC
    By pazko1125 in forum mel PIC BASIC
    Last Post: - 2nd October 2008, 16:26
  3. saving RCREG to word
    Last Post: - 15th September 2008, 14:51
  4. Replies: 288
    Last Post: - 25th August 2008, 17:53
  5. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 18:24
