I2c
Results 1 to 3 of 3
Thread: I2c
    Mark Scotford's Avatar
    Mark Scotford Guest
    Default I2c
    Can somebody help me please with some sample code. I have not used I2C before and I need to store a variable (B28), with a value between 1-9999 in an external memory EEPROM device, 24A65. All of the device address pins are held down to ground. My code does not work, please can you help.
    HOME1:
    I2CREAD PORTB.4,PORTB.5,%10100000,#B28
    B28 = B28 + 1
    PAUSE 500
    I2CWRITE PORTB.4,PORTB.5,%10100000,#B28
    LCDOut $FE,1,#B28
    PAUSE 500
    GOTO HOME1
    Thanking you in anticipation.
    Mark in Spain
    Feb 2004
    Germany
    Mark,
    try the following:
    B28 var word
    Adr VAR Byte
    B28=1245 ' Value to write
    Adr=0 ' EEPROM Location to write to
    I2CWRITE PORTB.4,PORTB.5,%10100000,Adr,[B28]
    Pause 50
    I2CREAD PORTB.4,PORTB.5,%10100000,Adr[B28]
    PAUSE 50
    LCDOut $FE,1,DEC5 B28
    PAUSE 1000
    For reference see PBP Manual Section 5.34 & 5.35
    regards
    Ralph
    Mark Scotford Guest
    Thanks Ralph, now I understand.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. I2C slave
    Last Post: - 16th March 2008, 04:46
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
