How to set Tmr1 to interrupt every 5 seconds
Results 1 to 2 of 2
    Oct 2008
    Default How to set Tmr1 to interrupt every 5 seconds
    So I'm playing with DT's instant interrupts and even started to modify the T1CON register to adjust the prescaler. I'm using the 16F628A running at 4Mhz so it looks like the maximum time I can get from timer1 is about 0.5s
    4Mhz/4 = 1us * 65535 = 0.0655ms * 8 (max prescaler) = 0.524s and that seems to work as my led blinks around 0.5s ON, 0.5s OFF
    I'm very new to the interrupts and would like to trigger my interrupt if my switch on PortB.0 hasn't been pressed for at least 10 seconds.
    How can I do that?
    Tom
    @ __config _HS_OSC & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    SWITCH  VAR PORTB.0
    LED1     VAR  PORTB.1
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    T1CON = %00110001            ; Prescaler = 8, TMR1ON
    @ INT_ENABLE  TMR1_INT       ; enable Timer 1 interrupts
      PAUSE 1
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    Sep 2005
    Campbell, CA
    One way would be to increase your interrupt rate to once every 50 milliseconds. In your ISR, check for PORTB.0 to be low and increment a counter. If the counter reaches 200, before PORTB.0 goes low, then the button hasn't been pushed for 10 seconds.
    Charles Linquist
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  3. Can't ID interrupt source with this IntHandler??
  4. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
