Lower 4 Bits?
Results 1 to 5 of 5
Thread: Lower 4 Bits?
    Jul 2005
    Midwest
    Try-
    SecOnes var byte 'should be NIBBLE?
    Seconds var byte
    SecOnes = Seconds & $0f
    Or-
    SecOnes = SecOnes & $0f
    I forgot to add that there already is a SECONDS variable, and it still has the error. Why does it say $0f ???
    This should not return any errors.
    SecOnes var byte
    Seconds var byte
    Of course the result will be unknown since none of the variables are initialized, but it
    definitely should not return an error.
    Because a value of $0F (%00001111) ANDed with another 8-bit value will return all
    0's in the upper 4-bits of the result MASKing the upper 4-bits out.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thank you, Bruce for the explanation. I now understand how it works. I failed to explain that I'm trying to "add-on" (within the Main portion of my program) to DT's Elapsed_INT-18. That's why I said the Seconds variable was already declared. So, when I declare it again, I get the redefinition error. I'll try adding the SecOnes stuff to HIS program!
    Last Post: - 14th June 2016, 08:55
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. Replies: 5
    Last Post: - 30th April 2008, 21:01
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
