switch on 1 weak pullup on portb?
Results 1 to 5 of 5
    Default switch on 1 weak pullup on portb?
    Hello Everyone. Is there a way to switch on a weak pullup on just one port on a 16F73? I know how to do it on the 12F series and I know OPTION_REG.7=0 will switch on all of them on portb, but I only want portb.1 to have a weak pullup. Thank you.
    From the datasheet.
    Each of the PORTB pins has a weak internal pull-up. A
    single control bit can turn on all the pull-ups. This is performed
    by clearing bit RBPU (OPTION_REG<7>). The
    weak pull-up is automatically turned off when the port
    pin is configured as an output.
    And
    2: To enable weak pull-ups, set the appropriate TRIS
    bit(s) and clear the RBPU bit (OPTION_REG<7>).
    But I bet you want the other pins to be inputs also?
    Actually, I'm switching the other portb's back & forth from outputs back to inputs in different areas of the program. I don't believe you can turn the pullups on individually. It's all or none.
    Depending on what you are out putting to, an external pull up might be the best solution. Use a high value.
    Omaha, Nebraska USA
    For a weak pull-up, I'd suggest 100K. Otherwise, I'd use 10K.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  3. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  4. HSERIN doesn´t work
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 29th July 2007, 14:23
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
