POT command
Results 1 to 6 of 6
Thread: POT command
    Default POT command
    I haven't messed around with it yet but what I want to do is create a reasonably precise set of time delays with a PIC.
    I could program pins to do this as I only need several values but was thinking I bet I could do it with pot on a single input pin? (I've never used pot before)
    What would be cool is if the trimmer had enough range, I'd like to jump in several 5 second increments.
    Say, fully CCW = 15 seconds.
    As you move the pot CW, there would be a trigger point for 20 seconds, the next 25 seconds and so on....till "whatever"....40 seconds or so.
    As I fall into a range of values, an I/O pin would go high along with an led designating the delay time.
    b0 = 15 secs
    b1 = 20 secs
    b2 = 25 secs etc
    Feasible?
    Can you in essence make "pot" sort of a precision pot?
    Like....
    If blah blah = a range of values then delay = 20 seconds
    THANKS
    It could be done, But I think you would be happier with a 10 bit ADC.
    The pot as a voltage divider, no capacitors to mess with...measure the voltage, maybe even have a reference voltage to "tune" it.
    The manual even says the values have to be experimented with when using POT command.
    Yeah, I thought of that....haven't really done much with anything other than purely digital I/O stuff....it'll be fun to play with it.
    Also thought I could use the internal timers someway...
    Reset to zero every time it hits the maximum of 40 seconds and sample the timer in my loop, looking for a small range of values in the register that would denote 5 second increments?
    Another possibility?
    Sep 2006
    Indiana, USA
    Drugs er bad, MMmK? Don't do drugs...
    I'd go with the ADC, its easy to use, fewer parts, easier to scale.
    just say no to POT.
    Omaha, Nebraska USA
    I agree with mackrackit and Ryan7777. Use ADC capability; it is truly easy. I did a nice little thing with a 12F683 that reads three different pots for three different time values.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    One of my favorites
    http://www.rentron.com/PICX2.htm
  1. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 21:23
  2. PBP2.50b and POT command problem ?
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 13th October 2008, 18:14
  3. Replies: 4
    Last Post: - 24th January 2007, 23:20
  4. pot command
    Last Post: - 25th November 2006, 05:12
  5. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
