Here is your code with the configs added in. The PBP inc file has been commented out.
I even programmed a chip. I named the file "invent"
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3041&stc=1&d=122833886 7" />Code:'************************************************* *************** '* Name : CONTROLLER.BAS * '* Author : Giorgio Rossi * '* Notice : Copyright (c) 2008 Invento S.r.l. * '* : All Rights Reserved * '* Date : 26/11/2008 * '* Version : 1.0 * '* Notes : * '* Chip : PIC16F88 * '************************************************* *************** Asm ERRORLEVEL -306 ERRORLEVEL -205 Endasm INCLUDE "MODEDEFS.BAS" @__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF &_XT_OSC TRISA = %00000001 'RA0 Input TRISB = %00000000 'all PORTB output ANSEL = %00000001'only porta.0 is analogue ADCON1 = 7'right justify the result(top bits are read as zero) CMCON = 7 'Turn off comparators adval VAR BYTE i var BYTE RPM VAR BYTE ' Define ADCIN parameters Define ADC_BITS 8 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 50 ' Set sampling time in uS PAUSE 500 loop: ADCIN 0,adval serout PORTB.6,n2400, [$FE, 1] serout PORTB.6,n2400, [$FE, 2, "pressione ", #adval] serout PORTB.6,n2400, [$FE, $C0, "giri", #rpm] IF adval < 90 THEN HIGH PORTB.4 endif IF adval > 120 THEN LOW PORTB.4 endif COUNT PORTA.2,250,RPM for i = 1 to rpm toggle PORTB.5 PAUSE 25 NEXT i LOW PORTB.5 GOTO loop 'repeat
