PICKIT2 - PBC Pro - PIC16F88 TROUBLE
Results 1 to 16 of 16
    Nov 2008
    Default PICKIT2 - PBC Pro - PIC16F88 TROUBLE
    Hello all,
    today have buyed the pickit2dp and running, I've too mounted a 18 dip pin socket in a board connected with the ICSP signal.
    It's all ok with pic 16f628 and an old hex file compiled with PBC 2.40 and MPASM 6.6, but with 16f88 compiled with PBC pro amd MPASM 8.10 have this alarm message
    http://www.picbasic.co.uk/forum/atta...1&d=1216305160
    Also with a new project with PIC16f628 and this new compiler/assembler/programmer don't work.
    I've tryed also to compile and program the micro but with the oscilloscope the micro seem dead, only the oscillator work.
    I've tryed with PM and MPASM too, but i'm not able to include "PIC16F88" or
    any Config for _XT_OSC and other
    The code :
    '* Name : CONTROLLER.BAS *
    '* Author : Giorgio Rossi *
    '* Notice : Copyright (c) 2008 Invento S.r.l. *
    '* : All Rights Reserved *
    '* Date : 26/11/2008 *
    '* Version : 1.0 *
    '* Notes : *
    '* Chip : PIC16F88 *
    INCLUDE "MODEDEFS.BAS"
    TRISA = %00000001 'RA0 Input
    TRISB = %00000000 'all PORTB output
    ANSEL = %00000001'only porta.0 is analogue
    ADCON1 = 7'right justify the result(top bits are read as zero)
    CMCON = 7 'Turn off comparators
    adval VAR BYTE
    i var BYTE
    RPM VAR BYTE
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    PAUSE 500
    loop:
    ADCIN 0,adval
    serout PORTB.6,n2400, [$FE, 1]
    serout PORTB.6,n2400, [$FE, 2, "pressione ", #adval]
    serout PORTB.6,n2400, [$FE, $C0, "giri", #rpm]
    IF adval < 90 THEN
    HIGH PORTB.4
    IF adval > 120 THEN
    LOW PORTB.4
    COUNT PORTA.2,250,RPM
    for i = 1 to rpm
    toggle PORTB.5
    PAUSE 25
    NEXT i
    LOW PORTB.5
    GOTO loop 'repeat
    Any help will be apreciated,
    Thanks a lot
    giorgio
    Last edited by inventosrl; - 2nd December 2008 at 21:53. Reason: Mistaked attachment
    You do not have to include pic16f88 if you are using MCS, it does it for you when you select 16f88 at the top of MCS, ELSEWISE it would have to be in the same directory as your code, in order to be found.
    Please show us how you wrote the config statement exactly.
    Nov 2008
    Hello Joe,
    this line
    @ __config _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLR_ON & _BODEN_ON & _WRT_PROTECT_OFF
    but in any case (with or without this config statement), have the same error and, after compiling and programming the micro don't work.
    Nov 2008
    Joe, this it's the error of MCS Plus while try to compile with the config statement :
    Error [126] c:\pbp\invento\contro~1.asm 101 : Argument out of range (not a valid config register address)
    Here is the top part of the code from a set up I have working.
    '16F88
    DEFINE OSC 8
    OSCCON= %01110100
    @__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF &_INTRC_IO
    This is using the internal OSC, but you should get the idea.
    You can look in the PicBasic inc file and the inc file in MPASM Suite for all of the possibilities.
    Quote Originally Posted by inventosrl View Post
    OK, open the assembly file the error lists, I think your file is controller.bas, so open controller.asm and look at line 101 and see what it is objecting to. I will play with your code when I get back to my own computer.
    EDIT: ok Tested and working with your code set for 4 mhz, as for the error, I get it too:
     @ __CONFIG _CONFIG1, _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLR_ON
    Nov 2008
    Hello, I use this :
    PICBASIC PRO(TM) Compiler 2.50
    MPASM V.5.2
    MPLAB 8.10.00.00
    MicroCode Studio Plus ver. 3.0.0.5
    Pickit2 Application Version : 2.55.01
    Device File Version : 1.53.00
    OS Firmware Version : 2.32.00
    the first's line of code:
    '* Name : CONTROl.BAS *
    '* Date : 02/12/2008 *
    '* Version : 1.0 *
    '* Notes : *
    ----- snip
    MicroCode Studio Plus Error :
    Error [118] c:\invento\control.asm 469 : Overwriting previus address contents (2007)
    Line [118] :
    _MCSBankEnd EQU MCSByte5
    giorgio
    See post #5
    Hello, I use this :
    MPASM V.5.2
    MPLAB 8.10.00.00
    '* Version : 1.0 *
    '* Notes : *
    ----- snip
    Line [118] :
    giorgio
    in the file you listed, the one from PBP 16f88.inc put a semicolon before this line, "<b> ;__config _CONFIG1, _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF</b> " that will cure the overwriting error. I have put one in here.
    Nov 2008
    See post #5
    Hello Dave, the same erron on pickit2
    Here is your code with the configs added in. The PBP inc file has been commented out.
    I even programmed a chip. I named the file "invent"
    '* Version : 1.0 *
    '* Notes : *
    Asm
        ERRORLEVEL -306
        ERRORLEVEL -205
    Endasm
    @__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF &_XT_OSC
    adval VAR BYTE
    i var BYTE
    RPM VAR BYTE
    PAUSE 500
    loop:
    ADCIN 0,adval
    IF adval < 90 THEN
    HIGH PORTB.4
    IF adval > 120 THEN
    LOW PORTB.4
    for i = 1 to rpm
    toggle PORTB.5
    PAUSE 25
    NEXT i
    LOW PORTB.5
    GOTO loop 'repeat
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3041&stc=1&d=122833886 7" />
    Nov 2008
    Hi Dave,
    thanks a lot
    please send me the file, so I can try.
    What's the first line in assebler?
    giorgio
    Nov 2008
    Hi Dave, I've look that you use MPASM,
    please post me this file (16f88.inc)
    thanks a lot
    giorgio
    Nov 2008
    Hi Joe, don't work
    The file in the previous post is complete, just copy paste.
    Yep, I do not use anything else.
    This is what it looks like.
         NOLIST
        ifdef PM_USED
            LIST
            include 'M16F88.INC'	; PM header
            device  pic16F88, hs_osc, wdt_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F88, r = dec, w = -302
            INCLUDE "P16F88.INC"	; MPASM  Header
       ;     __config _CONFIG1, _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    The ASM stuff
    -306
    Stops this message
    Crossing page boundary -- ensure page bits are set.
    Not needed for your code, just habit
    -205
    Takes care of
    Found directive in column 1.
    This is just a warning, but it is irritating.
    Nov 2008
    Very thanks Dave,
    tomorrow morning I'm on duty.
    nice night
    giorgio
  1. using pbp pro with mplab and pickit2
    By rackflot in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 16:17
  2. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 10:23
  3. ADC trouble with PIC16F88
    By inventosrl in forum mel PIC BASIC
    Last Post: - 3rd December 2008, 13:56
  4. Replies: 8
    Last Post: - 7th December 2006, 16:42
  5. Need help converting to PB Pro from Mbasic Pro
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 11th February 2004, 08:43
