PICKIT2 - PBC Pro - PIC16F88 TROUBLE
Results 1 to 16 of 16
    Nov 2008
    You do not have to include pic16f88 if you are using MCS, it does it for you when you select 16f88 at the top of MCS, ELSEWISE it would have to be in the same directory as your code, in order to be found.
    Please show us how you wrote the config statement exactly.
    Hello Joe,
    this line
    @ __config _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLR_ON & _BODEN_ON & _WRT_PROTECT_OFF
    but in any case (with or without this config statement), have the same error and, after compiling and programming the micro don't work.
    Nov 2008
    Joe, this it's the error of MCS Plus while try to compile with the config statement :
    Error [126] c:\pbp\invento\contro~1.asm 101 : Argument out of range (not a valid config register address)
    Here is the top part of the code from a set up I have working.
    '16F88
    DEFINE OSC 8
    OSCCON= %01110100
    @__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF &_INTRC_IO
    This is using the internal OSC, but you should get the idea.
    You can look in the PicBasic inc file and the inc file in MPASM Suite for all of the possibilities.
    Quote Originally Posted by inventosrl View Post
    OK, open the assembly file the error lists, I think your file is controller.bas, so open controller.asm and look at line 101 and see what it is objecting to. I will play with your code when I get back to my own computer.
    EDIT: ok Tested and working with your code set for 4 mhz, as for the error, I get it too:
     @ __CONFIG _CONFIG1, _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLR_ON
    Nov 2008
    Hello, I use this :
    PICBASIC PRO(TM) Compiler 2.50
    MPASM V.5.2
    MPLAB 8.10.00.00
    MicroCode Studio Plus ver. 3.0.0.5
    Pickit2 Application Version : 2.55.01
    Device File Version : 1.53.00
    OS Firmware Version : 2.32.00
    the first's line of code:
    '* Name : CONTROl.BAS *
    '* Author : Giorgio Rossi *
    '* Notice : Copyright (c) 2008 Invento S.r.l. *
    '* : All Rights Reserved *
    '* Date : 02/12/2008 *
    '* Version : 1.0 *
    '* Notes : *
    INCLUDE "MODEDEFS.BAS"
    ----- snip
    MicroCode Studio Plus Error :
    Error [118] c:\invento\control.asm 469 : Overwriting previus address contents (2007)
    Line [118] :
    _MCSBankEnd EQU MCSByte5
    giorgio
    See post #5
    Nov 2008
    See post #5
    Hello Dave, the same erron on pickit2
    Here is your code with the configs added in. The PBP inc file has been commented out.
    I even programmed a chip. I named the file "invent"
    '* Name : CONTROLLER.BAS *
    '* Date : 26/11/2008 *
    '* Version : 1.0 *
    '* Notes : *
    '* Chip : PIC16F88 *
    Asm
        ERRORLEVEL -306
        ERRORLEVEL -205
    Endasm
    @__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF &_XT_OSC
    TRISA = %00000001 'RA0 Input
    TRISB = %00000000 'all PORTB output
    ANSEL = %00000001'only porta.0 is analogue
    ADCON1 = 7'right justify the result(top bits are read as zero)
    CMCON = 7 'Turn off comparators
    adval VAR BYTE
    i var BYTE
    RPM VAR BYTE
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    PAUSE 500
    loop:
    ADCIN 0,adval
    serout PORTB.6,n2400, [$FE, 1]
    serout PORTB.6,n2400, [$FE, 2, "pressione ", #adval]
    serout PORTB.6,n2400, [$FE, $C0, "giri", #rpm]
    IF adval < 90 THEN
    HIGH PORTB.4
    IF adval > 120 THEN
    LOW PORTB.4
    COUNT PORTA.2,250,RPM
    for i = 1 to rpm
    toggle PORTB.5
    PAUSE 25
    NEXT i
    LOW PORTB.5
    GOTO loop 'repeat
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3041&stc=1&d=122833886 7" />
    Hello, I use this :
    MPASM V.5.2
    MPLAB 8.10.00.00
    '* Version : 1.0 *
    '* Notes : *
    ----- snip
    Line [118] :
    giorgio
    in the file you listed, the one from PBP 16f88.inc put a semicolon before this line, "<b> ;__config _CONFIG1, _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF</b> " that will cure the overwriting error. I have put one in here.
    Nov 2008
    Hi Joe, don't work
  1. using pbp pro with mplab and pickit2
    By rackflot in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 16:17
  2. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 10:23
  3. ADC trouble with PIC16F88
    By inventosrl in forum mel PIC BASIC
    Last Post: - 3rd December 2008, 13:56
  4. Replies: 8
    Last Post: - 7th December 2006, 16:42
  5. Need help converting to PB Pro from Mbasic Pro
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 11th February 2004, 08:43
