Sleep & nap
Results 1 to 25 of 25
Thread: Sleep & nap
    Question
    You want a ~1 sec PAUSE ...
    use PAUSE 1000 !!!
    a PAUSE can be "interrupted" so, there are no problem to use it ...
    If you're using the Microchip USB loader, it may have WDT disabled in config.
    Try inserting WDTCON.0=1 before any NAP or SLEEP commands to enable WDT.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    One would have think that would work, but it did not
    What might be wrong?
    WDTCON.0=1
    sleep 1
    lcdout $FE, $C0, "ok"
    Can't still se the "ok"
    Can't still see the "ok"
    Could the problem come from the LCD setup ???
    pause 1
    lcdout $FE, 1
    pause 1
    Generally, we allow 500 ms min for the LCD Power on ...
    How long are you waiting? If the WDT poscaler in config is set to 32,768 it's going to take around 131 seconds before it wakes-up.
    -Bruce
    tech at rentron.com
    the WDTPS is 128 as in #9, and actually it takes several seconds before that sleep instrucion is reached in the demo code (#9) as well as in the "big" code where I spotted this phenomena/error/failure at first.
    I have never seen sleep working, yet...
    but I would really like to see it
    How are you setting the WDT postscaler to 128?
    -Bruce
    tech at rentron.com
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. Replies: 5
    Last Post: - 5th February 2006, 17:51
