That is when the fun starts
Can you post your whole code?
The actual problem might be someplace else.
Here, the fun has alredy started
DEFINE LOADER_USED 1
DEFINE RESET_ORG 1000h      ' For Microchip USB Bootloader
DEFINE INTERRUPT_ORG 1008h  ' For Microchip USB Bootloader
define WDT_ON
define WDTPS 128
DEFINE LCD_DREG       PORTD	' Set LCD Data port
DEFINE LCD_DBIT       4		' Set starting Data bit (0 or 4 if 4-bit bus)
DEFINE LCD_RSREG      PORTC	' Set LCD Register Select port
DEFINE LCD_RSBIT      2		' Set LCD Register Select bit
DEFINE LCD_EREG       PORTC	' Set LCD Enable port
DEFINE LCD_EBIT       1		' Set LCD Enable bit
DEFINE LCD_BITS       4		' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES      4		' Set number of lines on LCD
DEFINE LCD_COMMANDUS  2000	' Set command delay time in us, 2000 us = 2ms
DEFINE LCD_DATAUS     50	' Set data delay time in us, 50 us = 0,05ms
powerOut     var PORTE.0
onOffPressed var PORTD.2
b var byte
clear
TRISE = %00001000
TRISC = %10110000
TRISD = %00001100
powerOut = 1
pause 1
lcdout $FE, 1
pause 1
pstart:
  powerout = not onoffpressed
  lcdout $FE,2, "b=", dec b
  b = b + 1
  'nap 5
goto pstart
So, I can see b living with nap or sleep commented, but it hangs when not commented.
