Image capture using a microcontroller
Results 1 to 2 of 2
    plopes's Avatar
    plopes Guest
    Default Image capture using a microcontroller
    Morning! i'm making a school work related with image capture using a microcontroller.
    This work is totally new for me, reason why i'm having some difficulties. It consists in the using of a digital camera with 640 x 480 pixels resolution (VGA), that reads 30 frames per second. The microcontroller PIC24f is connected with a SD card where the data is stored.
    I ask if it is possible to record directly the data in the SD card or if it is necessary a memory RAM connected to the microcontroller and what type?
    I really appreciate any clarification.
    1. this is PBP and PBC forum.
    2. This PIC24 series is not supported by the above compilers.
    3. The project might be possible to work wth assembly code.
    4. It is a little difficult anyways... Good luck!
  1. remote code learning
    Last Post: - 21st February 2021, 15:38
  2. mS Timer
    By whmeade10 in forum mel PIC BASIC Pro
    Last Post: - 8th September 2020, 12:12
  3. Using hardware capture
    Last Post: - 25th March 2012, 05:52
  4. Using CCP1 and CCP2 to measure instant fuel consumption
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 20th September 2008, 15:50
  5. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 01:47
