DT CMP Interrupt Problem
Results 1 to 5 of 5
Threaded View
    Aug 2008
    Question DT CMP Interrupt Problem
    I'm using PIC16F877, and have 2 analog inputs IN1 and IN2. I want to generate interrupt if voltage IN1 > IN2. Do I keep reading the AD register and compare it with IN2 voltage during each CMP interrupt? Or is there a more efficient way to implement this?
    define OSC 20
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INT_LIST  macro    ; IntSource,  Label,  Type, ResetFlag?
           INT_Handler    CMP_INT,  _Int_Cmp,   PBP,  yes
    @    INT_DISABLE   CMP_INT     ;Comparator int
    ADCON1= %00000000      'enable all analog inputs
    LED var PORTB.7
    loop:
    'start ad here
    'end ad
    pause 50
    goto loop
    '---[CMP - interrupt handler]----------------------------------------------
    Int_Cmp:
    toggle LED
    'read and store ad result here
    @ INT_RETURN
    I haven't finish the code above, but am getting a compilation error in Microcode "symbol not previously defined [CMIF]". PLease help.
  1. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 02:34
  2. Replies: 1
    Last Post: - 3rd November 2006, 00:24
  3. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
