DT CMP Interrupt Problem
Results 1 to 5 of 5
    Aug 2008
    Question DT CMP Interrupt Problem
    I'm using PIC16F877, and have 2 analog inputs IN1 and IN2. I want to generate interrupt if voltage IN1 > IN2. Do I keep reading the AD register and compare it with IN2 voltage during each CMP interrupt? Or is there a more efficient way to implement this?
    define OSC 20
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INT_LIST  macro    ; IntSource,  Label,  Type, ResetFlag?
           INT_Handler    CMP_INT,  _Int_Cmp,   PBP,  yes
    @    INT_DISABLE   CMP_INT     ;Comparator int
    ADCON1= %00000000      'enable all analog inputs
    LED var PORTB.7
    loop:
    'start ad here
    'end ad
    pause 50
    goto loop
    '---[CMP - interrupt handler]----------------------------------------------
    Int_Cmp:
    toggle LED
    'read and store ad result here
    @ INT_RETURN
    I haven't finish the code above, but am getting a compilation error in Microcode "symbol not previously defined [CMIF]". PLease help.
    The 16F877 doesn't have a Comparator module.
    The 16F877A does.
    Aug 2008
    I don't have 16F877A now. If I continue to use 16F877, what is the best method to detect IN1>IN2?
    This means I don't have any interrupt, and I have to poll the go/done bit in ADCON0 while sacrificing on executing other task?
    The A/D module has an interrupt that fires when a conversion is complete.
    You don't have to sit in a loop polling the Go/Done bit.
    Aug 2008
    Oh, that's great. How do I implement this using DT interrupt?
    Below is what I'm currently doing, using pause 25ms before the next AD.
    define OSC 20
    ' Define ADCIN parameters
    Define  ADC_BITS        10     	' Set number of bits in result
    Define  ADC_CLOCK       3     	' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    50    	' Set sampling time in uS
    ADCON1= %00000111      'PIC16F877 all analog input except RE1,RE2
     'start AD here
            ADCIN 0, adval				' Read channel0 RA.0 to adval
            pause 25
            ADCIN 1, adval2				' Read channel1 RA.1 to adval
            pause 25
  1. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  2. Replies: 1
    Last Post: - 2nd November 2006, 23:24
  3. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
